06-30-2017, 12:53 AM | #1 |
Newbie Join Date: Jan 2017 Location: Rohnert Park
| Aluminum rear axle?
Pros and cons between the vanquish and rc4wd rear axle? Sent from my LG-H918 using Tapatalk |
06-30-2017, 02:47 PM | #2 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Aluminum rear axle?
You should try the new HR one. Uses dual 15x24x5 bearings and also hubs and upper link mounts are built in. The VP uses stock plastic hubs and upper link mount and only uses one 15x24 bearing. Rc4wd uses standard size bearings.
06-30-2017, 04:07 PM | #3 |
Where I was going to order doesnt have the HR ones, they have some HR but not the rear axle that's why I was asking. I am still running 4s not ready to make the jump as my son uses the yeti as well. Sent from my LG-H918 using Tapatalk |
06-30-2017, 05:35 PM | #4 |
The axle is really new so the place your looking at may not have it yet. But if vp or rc4wd is the only choice, I like the vp since it has one bigger bearing. Even on 4s, the bigger bearing is just added insurance.
06-30-2017, 10:43 PM | #5 | |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: Aluminum rear axle? Quote:
Thank you | |
07-02-2017, 06:38 PM | #6 |
Not sure, but I doubt it.
Aluminum rear axle? - Similar Threads | ||||
Aluminum Rear Axle Case | wings1024 | Vaterra Twin Hammers | 12 | 01-07-2017 11:23 PM |
Best aluminum rear axle for u4 on yeti | AWraith build | Axial Yeti | 39 | 10-18-2014 02:32 PM |
