01-03-2017, 11:00 PM | #1 |
Newbie Join Date: Jun 2016 Location: Mckees Rocks (Pittsburgh)
| Aluminum Rear Axle Case
I recently purchased a used VTH on ebay. While waiting for delivery I ordered the GCM TowerPlate and some gmade shocks. Also waiting for the IRIE Bellcrank to be back in stock soon and then order that too, then the front end should be complete. I am know looking at the rear end. I was interested what you all think of the RC4WD Aluminum Rear Axle Case Can anyone tell me anything about this Vanquish rear axle because I love the look and can not find any information on it anywhere |
01-03-2017, 11:55 PM | #2 | |
Quarry Creeper Join Date: Aug 2014 Location: Orange County
| Re: Aluminum Rear Axle Case Quote:
Sent from my SM-G920T using Tapatalk | |
01-04-2017, 10:33 AM | #3 | |
Rock Stacker Join Date: Jan 2014 Location: Belleville, Ontario, Canada
I have had the RC4WD axle housing for some time, works perfect, looks good, you just need to watch your weight distribution as it makes the rear even heavier. Are you planning on running your battery up front with the GCM plate? | |
01-04-2017, 11:59 AM | #4 | |
Thanks rcbasser, yes I am planning to put the battery upfront, should help balance it out | |
01-04-2017, 06:12 PM | #5 |
Rock Crawler Join Date: Jul 2005 Location: Playing with toys with my son's
I say if your going to go aluminum and not slide with plastic, looks would be the reason also. Nothing against RC4WD, I had one of there housings on a used TH I bought worked as it should. I just do not see the reason, they look the same as stock. If it were me I would go with this one it is perrdee. I have been contimplateing this one myself |
01-04-2017, 10:29 PM | #6 |
Newbie Join Date: Jan 2017 Location: Bellingham
I don't have a TH yet but I have been researching rear axle options. Take a look at Vaterra with SCX Currie Axle Upper Links - Vanquish Products for an option to mount an SCX10 axle to the TH. Ideally I would like to do the new currie Rock Jock SCX10 II axle on the TH project eventually.
01-04-2017, 10:54 PM | #7 |
So I did a little quick reading and to do the Currie axle I need: Vanquish Products Currie Rockjock SCX10 Rear Axle Assembly Silver VPS06606 AXIAL SCX10 Rear Straight Axle SHAFT 6x104.50mm (2pcs) AX30421 AXA1230 & AXA1221 Bearings AX30392 - Bevel Gear Set 38T/13T I have not read enough to see if I will have to do anything to the VTH front Diff setup or the transmission |
01-04-2017, 11:19 PM | #8 | |
01-04-2017, 11:22 PM | #9 |
You will not have to do anything with the front ring and pinion. Stock TH ring pinion is 40-14, ratio 2.857 the 38-13, ratio 2.923 will give you a slight under drive in the rear. Hardly noticeable anything that may be noticeable will be a benefit.
01-05-2017, 10:00 AM | #10 |
cool, so know I just have to save the cash to get it. I just recieved the VTH in the mail today. I will load some pics when I get a chance before I start breaking her down for the rebuild. |
01-05-2017, 11:37 AM | #11 |
Front end wheels need adjusted Tires and wheels look pretty cool [IMG][/IMG] Seller said that he used it for bashing only, so he locked the transmission into high gear [IMG][/IMG] Came with this ESC, going to replace with a Castle MMP and a Roc412 motor [IMG][/IMG] Received a feww goodies in the mail today [IMG][/IMG] |
01-05-2017, 05:29 PM | #12 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
I'm pretty confident that the RC4WD axle housing is discontinued, so that narrows your options down a bit, which is just as well. The RC4WD housing's only benefits over the stock housing are durability and weight down low. You can get those same benefits though from the Currie housing, and the Currie housing looks way cooler. Which is maybe why the RC4WD housing is discontinued... |
01-07-2017, 11:23 PM | #13 |
reverse the front diff???? how???? never mid figured it out Last edited by wings1024; 01-08-2017 at 12:34 AM. |
Aluminum Rear Axle Case - Similar Threads | ||||
xr-10 aluminum axle case | Madmitch15 | Axial XR10 | 8 | 03-21-2015 07:40 PM |
Aluminum Axle case | Leland915 | Tamiya TLT Crawlers | 61 | 11-02-2006 05:02 PM |
