Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Hot Racing Aluminum Transmission Case upgrade opinions
Old 07-15-2017, 07:28 AM   #1
Default Hot Racing Aluminum Transmission Case upgrade opinions
Doing alot of upgrades right now but mainly not looking for flashy upgrades. Is it worth putting on an aluminum tranny housing ??? Im sure it releases heat better than the stock plastic. Im looking at long run times and want this thing to last and take a beating.
Looking for your opinions
TrIkKeD is offline   Reply With Quote
Old 07-15-2017, 09:10 AM   #2
Default Re: Hot Racing Aluminum Transmission Case upgrade opinions
Yes.
84yoda is offline   Reply With Quote
Old 07-16-2017, 02:00 AM   #3
Still using original tranny case and gears that came with my kit build over a year ago. I use AVID ceramic bearings and clean and lube bearings and gears every 8 to 10 packs. I do replace ceramic bearings on a regular basis though as they get loose from the high speeds.
pro mod steve is offline   Reply With Quote
Old 07-16-2017, 06:20 PM   #4
Good to know. I appreciate it
Hot Racing Aluminum Transmission Case upgrade opinions - Similar Threads
what screws to mount Hot Racing aluminum transmission case? ussprinceton2004 Axial SCX-10 4 09-24-2015 10:27 PM
Hot Racing transmission case WesTX Losi Micro-Rock Crawler 10 02-06-2015 08:26 PM
Hot racing transmission case Mudman02 Axial Wraith 0 11-14-2014 05:48 PM
Aluminum Transmission case Hot racing or Vanquish? DrDiff952 Axial SCX-10 10 11-11-2014 05:10 PM
Hot Racing Transmission case BC-Brian Axial XR10 15 11-15-2012 04:52 PM
