Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: HR Aluminum rear axle spacer?
Old 04-19-2018, 10:59 PM   #1
Default HR Aluminum rear axle spacer?
Hey all,
Purchased a used hot racing rear axle. Snagged it for $80 shipped with 15 minutes run time on it. Only thing it didn't come with is the 15x18x3.1mm spacer. I have some dhawk aluminum spacers coming in on monday; will one of those work? If not, anyone know if they can be purchased separately?
JohnGrundy is offline   Reply With Quote
Old 04-21-2018, 12:13 PM   #2
Default Re: HR Aluminum rear axle spacer?
Hi,
I have the d-hawk spacer and measured it 15x18x4,85mm....
So quite a difference if you should have 3,1mm
xwoop is offline   Reply With Quote
Old 04-21-2018, 05:31 PM   #3
Originally Posted by xwoop View Post
Hi,
Thanks for the dimensions! I should be able to shave it down a bit.
HR Aluminum rear axle spacer? - Similar Threads
Aluminum rear axle? talento Axial Yeti XL 5 07-02-2017 06:38 PM
Aluminum Rear Axle Case wings1024 Vaterra Twin Hammers 12 01-07-2017 11:23 PM
Best aluminum rear axle for u4 on yeti AWraith build Axial Yeti 39 10-18-2014 02:32 PM
