08-31-2014, 09:28 AM | #1 |
Come and take them!® Join Date: Oct 2011 Location: Rolling Hill's of Maryland™
| Hunter711 YETI
Not much for build threads, but thanks to: BEEF TUBES The DMG VooDoo Crawler Innovations Tekin VP MIP Harley CARTER FAB STRC Hitec Airtronics Robinson Racing HOT RACING HPI Will be adding more vendor products as they become available (if they are functional, and serve a purpose). Last edited by Hunter711; 08-31-2014 at 10:28 AM. |
08-31-2014, 10:36 AM | #2 |
| Re: Hunter711 YETI
When installing VP Sheer Steering Rack (which is a must have item IMO), stretch servo saver spring about a 1/4" and will take slack up with out going through a lot of trouble with other fixes. Good till someone makes a better Servo Saver Assembly or eliminates it all together.
09-06-2014, 12:56 PM | #3 |
| Re: Hunter711 YETI
This standard servo mount:Servo Mount for Standard Size Servos In combination with: TZi spool winch or any servo spool type winch will work. New style Werty Made front bumper New* Steel Axial Yeti bumper.(Hopefully available 10-14 days, with several different powder coated colors to choose from) is the chitz! Last edited by Hunter711; 09-06-2014 at 01:29 PM. |
09-09-2014, 04:15 PM | #4 |
Rock Crawler Join Date: May 2008 Location: carson city
| Re: Hunter711 YETI
The 711 bumper is a go. I pick up the parts from the laser cutters in a little bit
09-09-2014, 04:30 PM | #5 |
| Re: Hunter711 YETI
Here's a big wet one for ya brah!
09-10-2014, 12:33 PM | #6 |
| Re: Hunter711 YETI
WERTY MADE front bumper style #711 He's got the plates done, just has to fab the up. |
09-10-2014, 12:36 PM | #7 |
| Re: Hunter711 YETI
Yes "the up" is the rough part.
09-10-2014, 12:41 PM | #8 |
| Re: Hunter711 YETI |
09-10-2014, 11:16 PM | #9 |
| Re: Hunter711 YETI
Rc4wd fair lead holes Vp 1" light bar spacing. |
09-11-2014, 12:55 PM | #10 |
| Re: Hunter711 YETI
The smash plate is being moved up (plate length extended from top to bottom) and the fair lead slot will be on plain with winch line spool through the shock tower. No abrasion factor with chassis. This will put a slight delay on production as to new plates being laser cut. Very Soon. |
09-12-2014, 01:59 PM | #11 |
| Re: Hunter711 YETI
WOOT! |
09-12-2014, 02:36 PM | #12 |
Rock Crawler Join Date: Sep 2011 Location: FNQ Australia
| Re: Hunter711 YETI
So when is it gonna get dirty ? Keen to see some action shots. |
09-12-2014, 03:02 PM | #13 | |
| Re: Hunter711 YETI Quote:
New universals. SA WEEETTT! | |
09-13-2014, 09:58 AM | #14 |
| Re: Hunter711 YETI
Filling the trailing arms with bonding compound was great idea. [QUOTE] VTHokie: My trailing arms are doing the exact same thing. I'm thinking about sticking some JB Weld in there until Vanquish releases their trailing arms. Remove screws, tape holes, use "Hard hot melt glue" and filled. Great fix! Adding RPM's A arms really stiffened the front up nice. Now Werty Made #711 front bumper and Tzi winch and my front end is DONE! |
09-13-2014, 02:57 PM | #15 |
| Re: Hunter711 YETI
First off, give credit when due: CKRC, thanks Steven (sales associate) good job! 1.75 days from time of order to my shop. Fantastic!!! Installed limiting straps and VP rear upper links. Very happy with both. |
09-13-2014, 06:30 PM | #16 |
| Re: Hunter711 YETI
Reshaped CFM side panels and cut styrene to make firewall/rockguard to protect ESC and keep motor compartment clean. EZ PZ!
09-13-2014, 08:06 PM | #17 |
Quarry Creeper Join Date: Mar 2014 Location: San Antonio
| Re: Hunter711 YETI
Not sure if you've run it yet or not but they are bending at the front of the links. Check out the pic at the front of my link where it's bowed. I've yet to do it, I think I worked about 80 hours this week. Rig is looking great though.
09-14-2014, 02:04 AM | #18 |
| Re: Hunter711 YETI
Those areas get filled today. Then the weak point becomes where the shock mounts to the arm. I can bend it easily with my hands. Reckon just have to wait for $100+ VP arms. Last edited by Hunter711; 09-14-2014 at 02:09 AM. |
09-14-2014, 10:33 AM | #19 |
Newbie Join Date: Sep 2014 Location: Palmerton,Pa
09-14-2014, 10:35 AM | #20 |
| Re: Hunter711 YETI
Im using the carter fabrication ones. I'm also doing a little bit of modification to them since the arms ar steel.
Hunter711 YETI - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
water yeti.. calling all yeti owners | going2fast | Axial Yeti | 11 | 11-02-2014 05:43 PM |
Yeti in GA | Crawlininga | Axial Yeti | 0 | 08-28-2014 04:10 PM |
