Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Top 10 Low Budget Fixes
Old 09-16-2014, 09:00 AM   #1
Come and take them!®
Hunter711's Avatar
Default Top 10 Low Budget Fixes
This has got to be one of them.
Don't remember who came up with it, but fricken great!
Remove servo saver spring, add 2 bearings, plus 4 shims to tighten chit up, and OMG, you'll crap your pants. This should only be done with HD servo!
I searched threads and don't remember who should get the credit. Doesn't really matter cause it's for the good of the community.
You know who you are!
Hunter711 is offline   Reply With Quote
Old 09-16-2014, 09:29 AM   #2
Default Re: Top 10 Low Budget Fixes
VP or Gearhead hubs with aluminum hexes. Gotta be with-in the top 3 for cheap upgrades.
tedo is offline   Reply With Quote
Old 09-16-2014, 09:34 AM   #3
Hunter711's Avatar
Originally Posted by tedo View Post
Gotta be in the top 3 for cheap upgrades.
This is Top Ten Thread. Move along, nothing happnin' here.
Old 09-16-2014, 10:58 AM   #4
binaryterror's Avatar
Traxxas turnbuckles have to be in this list. Various part numbers work and even at full retail cheap and fully adjustable ($8/set). Not to mention what local shop doesn't stock traxxas stuff.
binaryterror is offline   Reply With Quote
Old 09-16-2014, 11:13 AM   #5
Your welcome
k9popo is offline   Reply With Quote
Old 09-16-2014, 11:18 AM   #6
RPM Arms are 15 bucks....BUY EM lol
gottorque is offline   Reply With Quote
Old 09-16-2014, 01:25 PM   #7
Hunter711's Avatar
Front diff is smooth as silk now.
Old 09-16-2014, 03:55 PM   #8
Replace the front plastic nuts that the inner hinge pins screw into with M3 lock nuts. You can pop them out of the chassis with a small screwdriver.
While you're doing that, fill the diff housing with grease where it bolts to the chassis to keep dirt from getting in and causing havoc.
rm25x is offline   Reply With Quote
Old 09-16-2014, 04:42 PM   #9
Hunter711's Avatar
Excellent! This is a "must do" for everyone IMO. I used a dental pic, and popped them right out. Gettin' the M3 back in was a PITA. But that's always the case in that type of install.
Old 09-16-2014, 09:34 PM   #10
Learned something new again today. Thanks guys. Keep the coming...
difflock120 is offline   Reply With Quote
Old 09-16-2014, 10:03 PM   #11
While I can't take credit for the idea but if your looking to gain some ride height in the front try some 90mm springs. I used Axial 2.25lb green 90mm springs, good for 3/4 inch to a 1 inch over the stock tide height in the front.
SteveC6R is offline   Reply With Quote
Old 09-17-2014, 02:31 PM   #12
Fix that ridiculous looking forward slant @ interior...
BC Racing is offline   Reply With Quote
Old 09-17-2014, 04:27 PM   #13
Now this may not be cheap to some kids who are complaining about loose screws and such, but put a decent RX / TX in it.
I just bound my Futaba (had an extra receiver laying around), and the TX adjustments are phenomenal (obviously).
Steering speed adjustments, fwd acceleration, end points, etc. really make a world a difference.
And it's free.
That stock equipment is real bare bones...
Old 09-17-2014, 04:33 PM   #14
And it's free.
I use a newer flysky. Gt3c I believe. Works with axial receivers, extra receivers can be bought for $9, fully digital, adjustable everything and 10 model memory for CHEAP
SoCal Crawlr is offline   Reply With Quote
Old 09-19-2014, 07:12 AM   #15
Have an old scx stock link laying around....do yourself a favor and make this. Snaps/holds in place with body up or down, makes life under the hood (battery changes/what nots) oh so much better.
Old 09-19-2014, 07:41 AM   #16
If using the stock ESC, upgrade the firmware. Not only is it cheap but also important. It reduces the tendency for the ESC to thermal going over very slow terrain. I'm going to try to get as much use out of the stock motor/ESC before I change to a Pro4 HD and RX8.
Eric1138 is offline   Reply With Quote
Old 09-19-2014, 08:47 AM   #17
Rock Concepts's Avatar
Yep Castle Link is Awesome!! put a liitle mor boost in it and she sceams!!
Rock Concepts is offline   Reply With Quote
Old 09-19-2014, 10:12 AM   #18
Thumbs up Re: Top 10 Low Budget Fixes
Good fix!
Apmcrx is offline   Reply With Quote
Old 09-19-2014, 11:17 PM   #19
I also just did this and used the same TX, not bad kit for $60!
Tower513 is offline   Reply With Quote
Old 09-22-2014, 10:01 AM   #20
Locktight all 4 screws on wheels to avoid loosening them and then destroying the hub with the pin.
Locktight all shafts pinscrews, I destroyed my rear shaft when it got loose.
Locktight is a Yeti´s friend
Rockatanski is offline   Reply With Quote
Top 10 Low Budget Fixes - Similar Threads
low budget 8x8 sloppy 1.9 Scale Rigs 40 02-27-2011 02:53 PM
Which is the best low-budget crawler? roksraka General Crawlers 30 05-13-2009 12:05 AM
Low budget OG WK ZUKMAN HPI Wheely King 4 02-10-2008 07:27 AM
help with low budget theshimonator Newbie General 5 01-10-2007 03:49 PM
low budget Don Tamiya TLT Crawlers 20 09-27-2005 02:22 AM
