09-19-2014, 09:32 PM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: Mission viejo
| Need opinions- Mamba Max Pro vs RX8
Loving my Yeti! biggest downfall about it for me and what I want my first upgrade to be is fixing the damn esc. Motor temps were at 120 today, esc was at 160. I've thermaled it twice and although I usually love castle products, this esc is not cut out for this truck. I have three options, buy an esc fan (cheapest, but limited long term) , a rx8 or just a more capable castle esc (with a built in fan) A rx8 and a mmp will let me run a pro 4 Hd in the future. so is the rx8 worth the higher price? Which will work best with my stock motor and which will work best with a pro4 down the road? Thanks! |
09-19-2014, 09:34 PM | #2 |
Pebble Pounder Join Date: Jan 2014 Location: Reynoldsburg
| Re: Need opinions- Mamba Max Pro vs RX8
I just ordered an MMP, but nowhere in the literature did it day what amperage it could handle...
09-19-2014, 09:35 PM | #3 |
It's capable of running 6s, it's a much more powerful esc than the rebranded sidewinder that comes stock. Plus has that built in fan. Anyone running a pro4 setup, what are your motor and esc temps like? |
09-19-2014, 09:39 PM | #4 |
Rock Stacker Join Date: Jul 2014 Location: Gilroy, CA
The MMP has a built in BEC. Is it suitable for a high torque servo like a hitec 7950? Don't want to muddy the waters, but if it would save buying and installing a ln external BEC, might be nice
09-19-2014, 09:42 PM | #5 |
I run a 7955 so that would be sweet, doesn't the rx8 also have one?
09-19-2014, 09:48 PM | #6 |
Again, don't want to derail the thread from pros and cons of both ESCs, but the MMP has a BEC that can be adjusted via Castle Link. The RX8 has an internal BEC but my understanding is its a constant 6v and can't be changed. Most hitec servos like the 4.8-6.0v range anyway.
09-19-2014, 09:50 PM | #7 |
MMP is almost $80 cheaper.
09-19-2014, 10:17 PM | #8 |
Quarry Creeper Join Date: Mar 2013 Location: Pilipinas
since you're getting a Castle Link if you're going to get an MMP anyways, check this out -- Traxxas Funny Car Castle Creations ET-3S ESC Speed Control just reflash with the MMP firmware to make it a legit MMP (instructions in the interwebz), using 2 and ordered my 3rd just this morning. best option if you want top of the line for less $$. |
09-19-2014, 10:23 PM | #9 |
Rock Stacker Join Date: May 2011 Location: WA
So why isn't anyone considering the sidewinder 8th? Has an 8 amp bec non sensored like the factory, waterproof and only like 85 bux off eBay.
09-19-2014, 10:36 PM | #10 |
Well if I'm buying a new esc I'm looking for something that can run sensored for a future motor upgrade
09-19-2014, 10:40 PM | #11 | |
| Re: Need opinions- Mamba Max Pro vs RX8 Quote:
Edit: does have a sensor port! Now my only question is that as far as I can tell it is still limited by traxxas to 3s, which is technically fine for my use, but I'm wondering if anything else is limited that a regular mmp can do that this cannot? Edit 2 http://traxxas.com/forums/showthread...ed-Castle-ESCs You sir may have just found the holy grail for all yeti owners Last edited by SoCal Crawlr; 09-19-2014 at 10:50 PM. | |
09-19-2014, 11:01 PM | #12 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
I upgraded my mmp to a RX8 about a year ago and my thermaling issue went away. Much more powerful esc, IMO.
09-19-2014, 11:11 PM | #13 |
| Re: Need opinions- Mamba Max Pro vs RX8 this forum is for the good of the community right? i've one with Roc412 on my scx10, another on my Yeti with the stock motor right now (Pro4HD arriving soon), both reflashed with legit MMP software. i am getting another for a future build. ;)
09-19-2014, 11:52 PM | #14 |
RCC Addict Join Date: Aug 2012 Location: Philippines
That ET-3s firmware mod.... GENIUS. You can get the traxxas ESC for under $70! |
09-20-2014, 12:59 AM | #15 | |
Rock Stacker Join Date: Nov 2013 Location: Meridian, Idaho
09-20-2014, 01:57 AM | #16 |
Just for anyone following, I ordered one of the eBay finds.. Couldn't pass up the price, and considering I already have a castle link, seems like a good fit. Thanks all for the feedback, and for everyone else feel free to chime in with your thoughts in the event it can help anyone else!
09-20-2014, 02:27 AM | #17 |
Quarry Creeper Join Date: Dec 2012 Location: Seattle
When I want a crawler ESC that is waterproof I use the MMP and waterproof it. For everything else I use RX8's. Can't beat the ease of modifying settings, and the operation of a Tekin RX8. Much more bang for the buck. |
09-20-2014, 03:05 AM | #18 | |
09-20-2014, 08:37 AM | #19 |
RCC Addict Join Date: May 2009 Location: Weston
Not sure anybody posted it yet but he MMP is roughly an 80amp ESC. Don't let the capability of 6S confuse you. When you go up in volts and down in kv it becomes more efficient and require less amps. This is why 4x4SC is so taxing on electronics. High kv and low voltage means very high amps. |
09-20-2014, 09:20 AM | #20 | |
I just saw this thread last night then looked and jumped on that same deal likely. (59.99 for a brand new ET-3S.) Can't wait to play with this! | |
Need opinions- Mamba Max Pro vs RX8 - Similar Threads | ||||
Mamba Max Pro motor options.. opinions wanted. | morg59jeep | Team Losi Comp Crawler | 24 | 11-27-2009 01:17 PM |
