02-07-2015, 10:58 PM | #1 |
Pebble Pounder Join Date: Sep 2010 Location: Lava Lands
| Yeti suspension thread?
Alright guys, I just finished building my Yeti kit and I can't believe how bad the suspension works. I've searched and everything seems to be buried on page 13 of a build thread. Lets start a new thread that just talks about suspension modifications. What your running and how it works. I built the kit per the specs. and the rear seems to pack out and kick, it needs more compression dampening and/or faster rebound. Not sure if it needs stiffer springs or thicker oil. It's blatantly obvious that the sway bar links cause the rear to bottom out leaving 1/2 to 3/4 inch of travel remaining. I just built shorter sway bar links out of extra parts tree stuff. Moved shocks to more vertical spots to increase spring/ rising rate. I'll report back with my results. Front: kit springs 30wt. oil Shocks in outer upper hole Rear: kit springs 30wt. oil shocks in rear upper hole shortened sway bar links Lets do this, sticky? |
02-07-2015, 11:09 PM | #2 |
RCC Addict Join Date: Aug 2012 Location: Philippines
| Re: Yeti suspension thread?
For best results with stock parts, run the shocks in the rear holes on both the upper and lower mounting doors. Run 30wt or greater oil. With stock springs add lots of preload. You don't really need the suspension to bottom out IMO. |
02-08-2015, 07:13 PM | #3 |
Pebble Pounder Join Date: Mar 2008 Location: sherbrooke
I'm also interested to see what people steup they suspension.stock rtr tent to nose dive the rear seems to botom and them kick it.
02-08-2015, 08:00 PM | #4 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
Does the kit not come with various pistons? May need some playin with those, oil wt and springs along with preload settings to get it all right. When i was looking at the RTR 1/8 Yeti at the LHS... noticed right away how soft and sloppy this thing felt. |
02-08-2015, 08:00 PM | #5 |
| Re: Yeti suspension thread? |
02-08-2015, 08:09 PM | #6 |
Rock Crawler Join Date: May 2009 Location: Texas
I added some spring compressors from slash and worked just right on the rear
02-09-2015, 11:46 AM | #7 |
Rock Stacker Join Date: Jan 2010 Location: Oklahoma City
I put Axial Medium (green) springs on the rear. For oil I went with 40wt rear/20wt front. I also rebuilt the shocks with the optional machined pistons. Added a bit of preload to both ends. Works perfect for me now. |
11-04-2015, 02:43 PM | #8 | |
Rock Stacker Join Date: Mar 2014 Location: North Bay
| Re: Yeti suspension thread? Quote:
Sent from my LG-D852 using Tapatalk | |
11-04-2015, 03:18 PM | #9 |
Quarry Creeper Join Date: Jan 2014 Location: Ukiah
I have the RTR and just swapped the lil for 32.5wt in the front and 30wt in the rear. Shocks are positioned: Ft, upper middle and lower outside (towards wheels); Re, upper rear mount, lower also towards rear most mount using SSD trailing arms. Preload set about half up front and almost cranked all the way down for the rear. I also swapped the link mounts on the tub to give a lil more triangulated geometry and flipped the axle mounts to level out axle pinion angle. Haven't ran it like this yet so we'll see how it goes Sent from my LGUS990 using Tapatalk |
11-04-2015, 05:17 PM | #10 |
Rock Stacker Join Date: Jul 2014 Location: Brasil
I used the rear shocks of the Exo (103mm - Yellow Springs) in front of the Yeti with some changes. Improved in fast corners. Last edited by ACR; 11-04-2015 at 05:21 PM. |
11-05-2015, 04:30 AM | #11 |
Newbie Join Date: Aug 2015 Location: Australia
Proline pro specs up front on purple super hard springs
11-06-2015, 05:04 AM | #12 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
11-06-2015, 09:21 AM | #13 |
11-06-2015, 06:08 PM | #14 |
Quarry Creeper Join Date: Jan 2010 Location: Lunenburg
My Yeti kit Ikons seem to be working much better now since switching to the 3 hole pistons in the rear with 30wt and 45wt in the front. I had some old Berg shock springs that I'm using on both ends.. They're pretty close to the Axial yellows that I was previously using, just longer. Also added STRC aluminum caps.
11-06-2015, 07:10 PM | #15 |
Pebble Pounder Join Date: Aug 2014 Location: Perth Western Australia
If anyone is interested, I race my Yeti in U4 down here in Western Australia. below is what i have come to so far the best set up for U4 rock racing, I run the PitBull RB2's which gives a little more ground clearance and then sit the rig nice and flat. Front 60Wt Kit Pistons 4.33lb Firm Yellow Sprngs (No pre load) Axial Exo Sway bar kit (Hard) Rear 50Wt Variable Rate kit pistons (Installed for Slower rebound and faster compression) 3.01lb Super Firm Blue Springs (No Pre load) Vanquish Sway Bar The variable pistons installed in slow rebound stops about 99% of the donkey kicking while jumping. Check out page 54 of your manual for the shock tuning guide from Axial Hope it helps out a fellow Yeti owner |
11-06-2015, 08:36 PM | #16 |
Rock Stacker Join Date: Apr 2012 Location: Sydney Australia
| Re: Yeti suspension thread? Good to hear some confirmation of what I've been thinking for when I start my build. I'd already ordered the same springs as well so seems my theory is on the right track.
11-08-2015, 10:18 AM | #17 |
11-08-2015, 01:38 PM | #18 |
Pebble Pounder Join Date: May 2010 Location: canada
Yeti suspension thread? - Similar Threads | ||||
Yeti XL Aftermarket Thread | Sneetches | Axial Yeti XL | 515 | 06-20-2019 06:01 AM |
Axial yeti xl video thread | keebler1510 | Axial Yeti XL | 1 | 01-25-2015 04:42 PM |
YETI Sightings Thread | Ty@Tekin | Axial Yeti | 1 | 08-04-2014 03:58 PM |
Suspension thread: What you got in your SCX10 | 06ToasterBox | Axial SCX-10 | 1 | 02-23-2013 06:47 PM |
Is there a shocks/suspension thread?? | Tmods | Newbie General | 5 | 01-22-2010 07:01 AM |
