Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Yeti suspension thread?
Old 02-07-2015, 10:58 PM   #1
Default Yeti suspension thread?
Alright guys, I just finished building my Yeti kit and I can't believe how bad the suspension works. I've searched and everything seems to be buried on page 13 of a build thread. Lets start a new thread that just talks about suspension modifications. What your running and how it works. I built the kit per the specs. and the rear seems to pack out and kick, it needs more compression dampening and/or faster rebound. Not sure if it needs stiffer springs or thicker oil. It's blatantly obvious that the sway bar links cause the rear to bottom out leaving 1/2 to 3/4 inch of travel remaining. I just built shorter sway bar links out of extra parts tree stuff. Moved shocks to more vertical spots to increase spring/ rising rate. I'll report back with my results.
Front:
kit springs
30wt. oil
Shocks in outer upper hole
Rear:
kit springs
30wt. oil
shocks in rear upper hole
shortened sway bar links
Lets do this, sticky?
dusty husky is offline   Reply With Quote
Old 02-07-2015, 11:09 PM   #2
Default Re: Yeti suspension thread?
For best results with stock parts, run the shocks in the rear holes on both the upper and lower mounting doors.
Run 30wt or greater oil.
With stock springs add lots of preload.
You don't really need the suspension to bottom out IMO.
gbean is offline   Reply With Quote
Old 02-08-2015, 07:13 PM   #3
I'm also interested to see what people steup they suspension.stock rtr tent to nose dive the rear seems to botom and them kick it.
dubfreak is offline   Reply With Quote
Old 02-08-2015, 08:00 PM   #4
Does the kit not come with various pistons?
May need some playin with those, oil wt and springs along with preload settings to get it all right. When i was looking at the RTR 1/8 Yeti at the LHS... noticed right away how soft and sloppy this thing felt.
SwampDawg is offline   Reply With Quote
Old 02-08-2015, 08:00 PM   #5
MODERATOR™
EeePee's Avatar
Originally Posted by dusty husky View Post
sticky?
Gonna need to be a lot more betterer than this.
EeePee is offline   Reply With Quote
Old 02-08-2015, 08:09 PM   #6
I added some spring compressors from slash and worked just right on the rear
4X4 Freak is offline   Reply With Quote
Old 02-09-2015, 11:46 AM   #7
I put Axial Medium (green) springs on the rear. For oil I went with 40wt rear/20wt front. I also rebuilt the shocks with the optional machined pistons. Added a bit of preload to both ends.
Works perfect for me now.
BR549 is offline   Reply With Quote
Old 11-04-2015, 02:43 PM   #8
Yes, but the shocks are icons with machined delrin pistons. You could try the bypass pistons in the spares baggie. I found my yeti worked best with 10wt fluid in back, it allowed for nice quick rebounds with perfect compression. The problems i was having was whenever hitting a jump or any bump at high speed, the tires would bounce up like a donkey kick and i would nose dive or worse. After i put really light fluid, i could hit the same bumps as previous but without the donkey kick. Rears are mounted in the innermost holes and outer holes on the front lower arms and shock tower.
Sent from my LG-D852 using Tapatalk
vanwraith001 is offline   Reply With Quote
Old 11-04-2015, 03:18 PM   #9
I have the RTR and just swapped the lil for 32.5wt in the front and 30wt in the rear. Shocks are positioned: Ft, upper middle and lower outside (towards wheels); Re, upper rear mount, lower also towards rear most mount using SSD trailing arms. Preload set about half up front and almost cranked all the way down for the rear. I also swapped the link mounts on the tub to give a lil more triangulated geometry and flipped the axle mounts to level out axle pinion angle.
Haven't ran it like this yet so we'll see how it goes
Sent from my LGUS990 using Tapatalk
kookie31 is offline   Reply With Quote
Old 11-04-2015, 05:17 PM   #10
ACR
I used the rear shocks of the Exo (103mm - Yellow Springs) in front of the Yeti with some changes.
Improved in fast corners.
ACR is offline   Reply With Quote
Old 11-05-2015, 04:30 AM   #11
Proline pro specs up front on purple super hard springs
Lozza is offline   Reply With Quote
Old 11-06-2015, 05:04 AM   #12
How did you reverse your motor and transmission? What are the benefits?
CamaroTom is offline   Reply With Quote
Old 11-06-2015, 09:21 AM   #13
Im Brandon
Brandon's Avatar
Pictures of this? That should not be the case.
Brandon is offline   Reply With Quote
Old 11-06-2015, 06:08 PM   #14
My Yeti kit Ikons seem to be working much better now since switching to the 3 hole pistons in the rear with 30wt and 45wt in the front. I had some old Berg shock springs that I'm using on both ends.. They're pretty close to the Axial yellows that I was previously using, just longer. Also added STRC aluminum caps.
Hobine is offline   Reply With Quote
Old 11-06-2015, 07:10 PM   #15
If anyone is interested, I race my Yeti in U4 down here in Western Australia. below is what i have come to so far the best set up for U4 rock racing, I run the PitBull RB2's which gives a little more ground clearance and then sit the rig nice and flat.
Front
60Wt
Kit Pistons
4.33lb Firm Yellow Sprngs (No pre load)
Axial Exo Sway bar kit (Hard)
Rear
50Wt
Variable Rate kit pistons (Installed for Slower rebound and faster compression)
3.01lb Super Firm Blue Springs (No Pre load)
Vanquish Sway Bar
The variable pistons installed in slow rebound stops about 99% of the donkey kicking while jumping. Check out page 54 of your manual for the shock tuning guide from Axial
Hope it helps out a fellow Yeti owner
Teenracer is offline   Reply With Quote
Old 11-06-2015, 08:36 PM   #16
Good to hear some confirmation of what I've been thinking for when I start my build. I'd already ordered the same springs as well so seems my theory is on the right track.
apsilon is offline   Reply With Quote
Old 11-08-2015, 10:18 AM   #17
ACR
It is a RC4WD AX2 transmission, I love this transmission and decided to adapt the Yeti.
Old 11-08-2015, 01:38 PM   #18
How hard was it to adapt to the yeti? I have a ax2 tranny still nib.
honchoscaler is offline   Reply With Quote
Yeti suspension thread? - Similar Threads
Yeti XL Aftermarket Thread Sneetches Axial Yeti XL 515 06-20-2019 06:01 AM
Axial yeti xl video thread keebler1510 Axial Yeti XL 1 01-25-2015 04:42 PM
YETI Sightings Thread Ty@Tekin Axial Yeti 1 08-04-2014 03:58 PM
Suspension thread: What you got in your SCX10 06ToasterBox Axial SCX-10 1 02-23-2013 06:47 PM
Is there a shocks/suspension thread?? Tmods Newbie General 5 01-22-2010 07:01 AM
