Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: SSD knuckles rubbing axles
Old 01-29-2015, 01:50 PM   #1
Default SSD knuckles rubbing axles
Anyone else have this issue? The bit of slop in the axles seem to be binding a bit in the knuckle when turning, makes a clicking sound as it rubs, it appears the movement is normal in the shaft as I see no way of getting it out
Justin82 is offline   Reply With Quote
Old 01-29-2015, 02:09 PM   #2
Default Re: SSD knuckles rubbing axles
I use the Axial universals and they don't hit them even at full lock.
Are you using the stock dog bone set up?
Crank is offline   Reply With Quote
Old 01-29-2015, 02:45 PM   #3
SSD
The knuckles don't rub anywhere that I know of.
The clicking is the universal not the knuckle. Have you removed the O rings from the drive cups?
SSD is offline   Reply With Quote
Old 01-29-2015, 03:27 PM   #4
The clicking is the universal just I can feel it binding slightly? Didn't do it with the plastic knuckles, it's the shafts that came with the kit.. Sorry wish I knew how to explain it better, I didnt remove any orings. Il take it apart again with the manual in front of me when I get home
Old 01-29-2015, 03:39 PM   #5
SSD
The binding is also the universal.
The pivot point in the universals is not inline with the knuckle king pins. This causes them to bind slightly.
If you look at the knuckles from the front you will see what I mean.
Old 01-29-2015, 03:44 PM   #6
Ahh I see what you are saying! I will take em apart when I get home and do that, let you know how it goes. Now that's great customer service! Even though it's user error lol
Old 01-29-2015, 04:37 PM   #7
No matter if I line them up as soon as it turns from that point it clicks again... I'm not getting it! Il play with it for awhile and see
Old 01-29-2015, 04:54 PM   #8
I don't see where the kingpins affect the universal as it turns inside the knuckle, wich I why I'm stumped on this
Old 01-29-2015, 04:58 PM   #9
Mine work smooth as butter too. Not much left on the front end that's stock though. Are your bearings seated properly?
CREEPINKING is offline   Reply With Quote
Old 01-29-2015, 05:33 PM   #10
Doing it wen with the plastic knuckle back in.. Il try and post the vid
Old 01-29-2015, 05:40 PM   #11
Edit
Old 01-29-2015, 05:41 PM   #12
Sorry no audio il try again..
Old 01-29-2015, 06:38 PM   #13
So how do align the universal pins with the king pins?
Old 01-29-2015, 06:51 PM   #14
In your video you have to much movement in the universal.
Like CREEPINKING said did you make sure your inner bearing was seated in the knuckle?
Old 01-29-2015, 06:53 PM   #15
It also looks like your knuckle may be upside down.
Old 01-29-2015, 07:04 PM   #16
Ok, so I had to adjust the turnbuckles when I first put on the ssds to get the toe straight, I adjusted it back to manual spec and put the plastic back on, no click at all until I compress the shock with the a arm, and even then not bad really ,slight... So I guess I just have to adjust the turnbuckles to get it perfect with the ssds
Old 01-29-2015, 07:05 PM   #17
The bearing is seated, I put the knuckle on like they have in the pic on their web site
Old 01-29-2015, 07:13 PM   #18
There is a ton of play in the universal
Old 01-30-2015, 02:26 AM   #19
SSD
I dont think the turnbuckle/toe setting will make any difference.
Also you cant fix the kingpin/universal alignment as it is the way it has been designed.
Looking at the video, there is definately too much movement in the universal.
As others have said, I would make sure the bearings are seated 100% in the knuckles.
Old 01-30-2015, 07:00 AM   #20
Well this sucks.. Bearings are seated and it's still clicking, guess il just drive er!
SSD knuckles rubbing axles - Similar Threads
Ssd knuckles Cchapman Axial Yeti 0 12-23-2014 05:33 AM
Rubbing woes after installing VP knuckles and C's Shizanester Axial Wraith 18 09-04-2014 11:28 PM
xr10 knuckles and inner axles on scx10 axles wingnutcrawler Axial SCX-10 9 04-29-2013 06:57 AM
Knuckles rubbing Beadlock screw?? mcap Axial SCX-10 7 10-06-2012 08:21 PM
RPM Clawz rubbing on knuckles. ccampb04 Tamiya TLT Crawlers 4 03-21-2005 03:18 PM
