02-14-2015, 01:41 AM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: labrador
| Blackhawk, yeti prerunner
hey guys just thought id share some pics with you all. I recently picked up a Blackhawk shell by BittyDesign, the shell is designed to fit all SCT trucks available so as such has a decent WB. anyways ill let the pics do the talking after some triming and fitting of axial "blue"springs this is the result and a mounting method i came up with to use the existing mount holes now i still need to extended the body posts up to secure the shell to the chassis and maybe some more trimming. more to come |
02-14-2015, 02:27 PM | #2 |
Quarry Creeper Join Date: Jan 2011 Location: Michigan
| Re: Blackhawk, yeti prerunner
Alright! Looks really doable from those pics...even for someone as frabricatingly unstable as myself! I'm stoked to see how this one comes together.
02-15-2015, 07:25 AM | #3 |
Pebble Pounder Join Date: Mar 2008 Location: sherbrooke
nice project, thats one reson i bought a yeti to convert it to a desert truck
02-22-2015, 04:48 AM | #4 |
| Re: Blackhawk, yeti prerunner |
02-22-2015, 11:45 PM | #5 |
Quarry Creeper Join Date: Feb 2012 Location: Roseville
Sick!!
02-23-2015, 02:38 AM | #6 |
02-23-2015, 04:35 AM | #7 |
Hell yea! Looks sweet and aggressive. Really dig the purple. Are there any clearance issues with tire rub up front on compression? My Slash had to get a fairly big body lift when I changed to 2.8 wheels and bad lands, so I'm just curious I guess.
02-23-2015, 04:37 AM | #8 |
At max compression there will be a small amount of rubbing but theres not alot i could do. It has firm ax10 springs all round to lift the suspension and i trimmed the shell as much as possible without losing the truck look. The Trukkracea |
02-23-2015, 07:42 AM | #9 |
Pebble Pounder Join Date: Dec 2011 Location: Ohio
Line the areas where the tire rubs with some gorilla duct tape. Use it in the high impact areas as well. I use it on my race shells and it has worked well.
Blackhawk, yeti prerunner - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
2wd prerunner Yeti? | pastimesteve | Axial Yeti | 5 | 02-11-2015 05:04 PM |
