06-06-2015, 04:44 PM | #1 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Dirt in front diff Ok guys like the description says I've got dirt in the front diff again. This Yeti rtr came to me used on trade I pulled everything apart make sure everything was greased and put it back together. When I pulled the front diff apart yesterday it was full of small dirt and trash. I don't know if anybody has had this problem or if anybody is having this problem but this is what I did to solution part of the problem. I disassembled the front diff from the chassis. I found that the diff is not sealed on the bottom. There are also two small holes in the back of the diff case. I feel the two small holes with 1.5 millimeter grub screws I also use some weather stripping gasket and seal the bottom of the case to the chassis. |
06-06-2015, 05:34 PM | #2 |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
| Re: Dirt in front diff
Yeah, I get dirt in there also. It's an inherent design flaw I guess. Next time you tear into it post up what you find. I'm curious to see if your idea keeps the grit out or even a good portion of it.
06-06-2015, 06:29 PM | #3 |
| Re: Dirt in front diff Ok will do The diff case was nasty. If you look at the pinion and diff housing you can see how nasty it is. The stuff in the diff case was even worse. Last edited by greengoblin; 06-06-2015 at 06:39 PM. |
06-09-2015, 05:57 AM | #4 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
This is normal with nearly all 4wd rc race buggies as well. The easiest fix is a little grease where it meets (I happen to use Associated Black). Good seal and easy to remove. I just swapped front cases and gears, mine looks as clean as the day installed, and I didn't even do the set screw plugs, should have.
06-09-2015, 06:13 AM | #5 | |
Quarry Creeper Join Date: Nov 2014 Location: Reno
| Re: Dirt in front diff Quote:
06-14-2015, 09:41 AM | #6 |
Pebble Pounder Join Date: Dec 2014 Location: Duluth
interesting, those holes are filled with M3 grub screws during the build process for the Kit version.
06-15-2015, 04:41 PM | #7 | |
Mine must have been assembled on a Monday or Friday. As you see those holes were empty never had a set screw in it. Last edited by greengoblin; 06-15-2015 at 04:44 PM. | |
06-20-2015, 11:25 PM | #8 |
Dont feel bad, i almost finished my kit today, then i found out that they changed several parts in the manual (online) vs the paper manual i was shipped. had to rip out the transmission and adjust the servo and camber links and add some more grease and thread lock that was never called out originally.
06-22-2015, 03:01 AM | #9 | |
Newbie Join Date: Jun 2015 Location: Italy
If you didn't notice, another dimension change is for the slipper spring (p25). It should be 8.5 mm, not 6 mm. | |
09-24-2015, 05:29 PM | #10 |
| Re: Dirt in front diff I purchased a SSD axle and a Dlux fab larg bearing front diff. After i get them installed and run time on them i will let every one know how they hold up |
09-29-2015, 09:45 PM | #11 |
| Re: Dirt in front diff The new front diff came in today. So hear is the diff i sealed. I did it on the new diff also. This truck got sunk in the creek about a month ago by accident. I pulled the rear diff apart there was very little water in it so i pulled the transmission apart there was no water. The servo was fine but I did not pull the front diff apart because I wanted to put it through punishment. I wanted to see what it was going to look like after a few months of no maintenance well guess this is it. I installed a new Hd gear and shes back running. No dirt no water im happy. |
09-29-2015, 10:00 PM | #12 |
I wanna be Dave Join Date: Jul 2013 Location: Minneapolis
Just opened mine up to install a GCM diff cup. No dirt and I run in a sand dirt mix.
09-30-2015, 09:04 PM | #13 |
| Re: Dirt in front diff Mine was used when i got it so i don't know its life until i got it. |
Dirt in front diff - Similar Threads | ||||
front diff | vito | Axial Yeti XL | 3 | 05-10-2015 06:45 AM |
front diff? | hende | 1:1 Full Size Vehicles | 3 | 10-22-2012 04:10 PM |
independent front suspension and front diff build | canadian scx10 | Axial SCX-10 | 1 | 02-13-2011 07:52 PM |
