06-16-2015, 05:01 PM | #1 |
Newbie Join Date: Jun 2015 Location: texas
| new yeti already having problems
today i got a brand new yeti and right out of the box its having problems something in the rear diff/ drive shaft is grinding making a really loud noise right out of the box. does anyone know what it could be? it was literally doing it right away its brand new Sent from my SM-G920P using Tapatalk |
06-16-2015, 06:05 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: new yeti already having problems
1st look @ spur gear on trans. 2nd open rear diff & inspect Ring & pinion gear.
06-16-2015, 06:06 PM | #3 |
Quarry Creeper Join Date: Dec 2014 Location: Plainfield
That sounds like your rear ring and pinion, call axial customer support and they should send you new ones. That will get you up and running. In the Future, you may want to replace them with the HD gears (#AX30395). I run those front and rear with no problems, ALWAYS check the gear mesh and shim accordingly.
06-16-2015, 08:44 PM | #4 |
Rock Crawler Join Date: Mar 2013 Location: columbus
Thats the rear diff. I just destroyed 2 myself in under 3 hours. If you got it at a local hobby shop take it back and show them what is doing. Have them send it back or give you another one. If they give you any flack call axial. Sent from my SM-G900P using Tapatalk |
new yeti already having problems - Similar Threads | ||||
Just went out to the track for the FIRST TIME. Problems Problems Problems | flyingrc | Non Crawler RC's | 4 | 07-23-2012 10:19 PM |
Problems problems problems hope it's worth it in the end | TJcreeperJEEP | Venom Creeper | 9 | 12-22-2009 04:54 PM |
