10-22-2015, 03:37 PM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: Canada
| VP Bell crank |
10-22-2015, 04:14 PM | #2 |
| Re: VP Bell crank
I may need these, price isn't bad either.
10-22-2015, 06:32 PM | #3 |
Quarry Creeper Join Date: Dec 2014 Location: Northern VA
| Re: VP Bell crank
Excellent, not a necessary upgrade, but I got one anyways . Come on VP, let's see some proper yeti VVDs next! |
10-22-2015, 06:38 PM | #4 | |
Quarry Creeper Join Date: Dec 2014 Location: Plainfield
| Re: VP Bell crank Quote:
Not to get too far off of OP's point, back OT I think it is awesome to see these without a servo saver, because of how terrible the original design was. Might have to replace my STRC stuff... | |
10-22-2015, 06:49 PM | #5 |
| Re: VP Bell crank |
10-22-2015, 07:05 PM | #6 |
| Re: VP Bell crank
Dang, was the servo saver locked?
10-22-2015, 07:12 PM | #7 |
| Re: VP Bell crank
Yep
10-22-2015, 07:25 PM | #8 |
| Re: VP Bell crank
Lol yea, that'll do it. sadly it seems the only way to maximize the steering. I run mine with the spring and one cheapo bearing to allow some flex when I do an oopsie.
10-22-2015, 07:48 PM | #9 |
Rock Stacker Join Date: Apr 2012 Location: Sydney Australia
| Re: VP Bell crank
Wish they'd been out a few days ago when I placed an order. Would've saved shipping for a second order |
10-22-2015, 08:00 PM | #10 |
Quarry Creeper Join Date: Dec 2014 Location: Sacramento
| Re: VP Bell crank |
10-22-2015, 08:04 PM | #11 |
| Re: VP Bell crank
It's like my second time I hit a tree in the 4 months I've had. Sent from my VS986 using Tapatalk |
10-23-2015, 03:56 AM | #12 |
Quarry Creeper Join Date: Sep 2014 Location: UK
| Re: VP Bell crank
I'll be getting one of these too, as I lock my servo saver and that plastic arm has snapped so often. Kelsie, I never noticed that CVD in that pic before, good spot! |
10-23-2015, 05:27 AM | #13 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: VP Bell crank
I was less than impressed with my VP rack, hope for you guys that the bellcranks are better. Likely just aluminum copies of plastic parts though.
10-23-2015, 06:10 AM | #14 |
| Re: VP Bell crank
What is it about the rack you didn't like? Mine rubs on the centre drive shaft a bit at the front. |
10-23-2015, 06:29 AM | #15 |
| Re: VP Bell crank A half a second view of the picture posted will clearly show the difference between a stock part and the new rack. You're slipping Jacob.
10-23-2015, 07:31 AM | #16 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
| Re: VP Bell crank
How is this VP part any better than say the STRC or HR parts, though? I have the full STRC bellcrank setup and have yet to have any issues with it. So what makes the VP part any better other than it's VP?
10-23-2015, 07:32 AM | #17 |
| Re: VP Bell crank
Well it replaces the servo saver completely, no more needing to mod the current one to lock it out. Hopefully this will be stronger, because as you see above the arm on the plastic one tends to snap often with the mod in place.
10-23-2015, 08:39 AM | #18 | |
I just want someone to fix the less than ideal entire geometry of the steering system, guess that likely won't happen. Or maybe it just can't happen given the space without a ton of redesign that won't be bolt in. | |
10-23-2015, 09:14 AM | #19 |
| Re: VP Bell crank So other than replacing the very lacking servo saver, its not any better for someone who already has an entire aluminum bellcrank setup and Dude Rang eliminator.
10-23-2015, 09:29 AM | #20 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
| Re: VP Bell crank What servos are people running that use this or eliminate the servo saver. I could never keep mine alive when I did the mod. Thanks
VP Bell crank - Similar Threads | ||||
Bell Crank Steering? | STANG KILLA SS | General Scale Talk | 15 | 04-07-2020 09:31 PM |
What bell crank should I choose? | Tzicul | Axial Yeti XL | 76 | 10-10-2016 03:14 AM |
