08-20-2015, 03:34 PM | #1 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| What bell crank should I choose?
I just ordered a YXL kit and don't know what should I choose between Dhawk and HR bellcrank. Is there any difference between them? I know I have to order the aluminium spacer for the diffs from Dhawk and the MT4 wheels, is there anything else mandatory for a new kit? Thanks all! |
08-20-2015, 05:42 PM | #2 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Re: What bell crank should I choose?
I got the DHawk and NO problems and took less than 2 weeks to ship to way south texas. I have made 4 more orders since then and all arrived in less than 2 weeks and everything was top notch as far as fit and quality.
08-20-2015, 07:30 PM | #3 |
Rock Crawler Join Date: Jul 2015 Location: McKinney, TX
+1 Dhawk stuff is really good. I have the bellcrank, front diff case, spacers and rear driveshaft. All good stuff. Took about to weeks to get to North Texas. Apparently they have great shipping to Texas. lol
08-20-2015, 09:34 PM | #4 |
I have the HR upgrade but i would get the DHawk if i had to do it over again. See Post #98 Yeti XL Aftermarket Thread |
08-21-2015, 07:02 AM | #5 |
Rock Stacker Join Date: Apr 2015 Location: Thomasville
I have the dhawk, took about a week and a half, easy install, huge difference even with the stock servo. Highly recommend it!! I ordered the kit off eBay with the steering posts.
08-21-2015, 08:49 AM | #6 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
I too can attest to the Dhawk. I will say this. I needed to do a little sanding on the front edge of it because it was hitting the bulkhead at lock. Other than that, I really like it.
08-21-2015, 01:23 PM | #7 |
Well, it seems dhawk is the winner. I also prefere the dhawk, considering the pictures, seems to be much beefier. I will order it, together with the diff spacer and bearings. And at some point probably the rear drive shaft. I still have to figure the servo out, I don't think I'll spend $100-150 on a savox, futaba or hitec. Maybe some Turnigy, what do you think?
08-21-2015, 02:55 PM | #8 |
I almost purchased a Turnigy and/or a Solar Servo D772 when my Spektrum burned out. Most of the Turnigy's (at the time) shipped out of the international warehouse and I didn't know how long it would take to get to me. Solar Servo D772 quality seemed a bit sketchy to me. Since I couldn't drive my YXL w/o steering, I ordered a Savox 2270 from Amazon (Prime shipping) and it works really well. Do you have a BEC? |
08-21-2015, 03:16 PM | #9 |
Yes, I do have a bec. But I don't think I will use it. But for a different reason, not why you think ;) More details after mid september. I liven in Romania and a friend will bring my yxl from US early september. I have something in my mind, hopefully I will manage to figure it out. However I will still need a servo |
08-21-2015, 04:36 PM | #10 |
Keep us posted on the Turnigy servo. If it works well I'll get some for backups. Post pics of a YXL bashing it up in Romania! |
08-22-2015, 11:02 AM | #11 |
I just ordered a Turnigy TGY-DS3509MG together with aluminum one-way universal servo arm 151000136. Next in line are bearings 15x21x4 for front diff, I'll get them probably from Acer or Avid, at Boca they are rather expensive, and I don't know what to do about rear drive shaft. Should I get one from Dhawk or wait until I'll broke the original one? Last edited by Tzicul; 08-22-2015 at 11:47 AM. |
08-22-2015, 06:12 PM | #12 | |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Re: What bell crank should I choose? Quote:
Sent from my SM-N900V using Tapatalk | |
08-23-2015, 10:52 PM | #13 |
Can anyone tell me the difference between Dhawk and GPM rear driveshaft? Heavy Duty Steel Drive Shaft for Axial Yeti XL AX90032 AX920038 | eBay GPM Racing Axial Yeti XL Steel #45 Rear Drive Shaft - 1 Pc Set Black YTL237S |
08-24-2015, 12:45 AM | #14 | |
08-24-2015, 02:39 AM | #15 |
The pictures might be different, but the product is exactly the same ;)
08-24-2015, 12:01 PM | #16 |
I just ordered the dhawk one. Mine is twisted up like licorice. Sent from my SM-N900V using Tapatalk |
08-25-2015, 12:18 PM | #17 |
Does anybody knows or can measure the width of the Dhawk diff spacer? If I'll it order from Dhawk, it will take forever to get it to Romania, so I'm thinking to use a stock bearing (if it is thin enough) together with this Vespa ET2 50cc Pre 2000 Variator Shim Speed Up Set 15mm | eBay Last edited by Tzicul; 08-25-2015 at 12:27 PM. |
08-26-2015, 04:15 PM | #18 |
Just ordered GPM (aka Dhawk, or vice versa) parts from asiatees GPM Racing Axial Yeti XL Aluminium Steering Assembly - 1Set Blue YTL048 GPM Racing Axial Yeti XL Aluminium Steering Mount - 1Pc Set Blue YTL049 GPM Racing Axial Yeti XL Aluminium Steering Post - 1Pr Set Gun Metal YTL048A Just save $12 (no bearings, indeed, but I'll have the ones from the kit) Also I decided not to go with Dhawk spacer, but to use a third bearing as spacer together with this Vespa ET2 50cc Pre 2000 Variator Shim Speed Up Set 15mm | eBay That way I'll have some spares if I'll ever need them And, of course, rear driveshaft GPM Racing Axial Yeti XL Steel #45 Rear Drive Shaft - 1 Pc Set Black YTL237S |
09-15-2015, 10:46 AM | #19 |
Parts started to come Last edited by Tzicul; 09-15-2015 at 10:51 AM. |
09-18-2015, 07:46 AM | #20 |
Newbie Join Date: Sep 2015 Location: Houston
Dhawk drive shaft and bellcrank installed on a RTR Yeti XL. What an improvement! Also installed an aluminum servo horn and metal linkage there, then had to trim plastic, but it's much tighter steering.
What bell crank should I choose? - Similar Threads | ||||
Bell Crank Steering? | STANG KILLA SS | General Scale Talk | 15 | 04-07-2020 09:31 PM |
