Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: So loud!
Old 11-01-2015, 10:23 AM   #1
Default So loud!
I bought a yeti used from a member and I tore the whole truck down replaced all the bearings it has a steel spur & pinion, all steel gears and it is so ungodly loud is that normal? The truck also has the Traxxas Velineon VXL-3s system. I didn't know if the spur & pinion could be bad .
mudbeast2 is offline   Reply With Quote
Old 11-01-2015, 10:53 AM   #2
Default Re: So loud!
Check motor bearings. Before I sold my RTR Yeti, the stock Vanguard motor was getting loud. My kit setup is so quiet.
CamaroTom is offline   Reply With Quote
Old 11-01-2015, 11:06 AM   #3
Thanks bud! That makes sense. That's the only thing I haven't done.
Old 11-01-2015, 11:10 AM   #4
Steel spur gears are most definitely louder, especially when bench testing, but when you are out ripping around it isn't so bad.
Cultus is offline   Reply With Quote
Old 11-01-2015, 11:15 AM   #5
Be very ocd about spur/pinion mesh.
You want almost zero gap on the teeth.
gbean is offline   Reply With Quote
Old 11-01-2015, 12:59 PM   #6
I ordered a rebuild kit for the motor. I'm also waiting for the rest of my parts to show up (hopefully this week). Ill keep you guys posted. As always thanks for the info.
Old 11-01-2015, 02:02 PM   #7
I don't think that motor/esc is adequate for a Yeti. A Yeti is much heavier than what traxxas includes that system with. Just a thought.
fr8cture is offline   Reply With Quote
Old 11-01-2015, 06:58 PM   #8
This system came with my Yeti. I do want to upgrade. I definitely want brushless sensored. Probably a Castle system being that I have a castle link. What would you guys suggest & what pinion/ spur combo?
Old 11-01-2015, 07:11 PM   #9
You could go with a MMP and a sensored motor of your choice. Castle doesn't make sensored motors.
Old 11-01-2015, 08:46 PM   #10
Thanks for the info, I haven't even started to look yet.
Old 11-02-2015, 05:55 AM   #11
After some looking, I think I may go with the Mamba Max Pro & Tekin 3000hd motor. I'm currently using a 64/14 spur & pinion. Any suggestions?
Old 11-02-2015, 06:14 AM   #12
That's a good combo.
Old 11-02-2015, 08:37 AM   #13
Exactly what I'm running.
Doesn't get hot.
Can even withstand the occasional bash on 4S!
Old 11-02-2015, 10:21 AM   #14
The steel spur and pinion is definitely loud. I almost changed mine back when I went steel on both. Doesn't seem so loud after a couple weeks. Now I don't even notice it.
BR549 is offline   Reply With Quote
So loud! - Similar Threads
It's loud! Mortimer Snerd Losi Micro-Rock Crawler 4 04-01-2010 10:05 PM
Runnin very loud Groundhog Venom Creeper 8 09-16-2009 02:50 AM
loud R2 tranny scale4x4 Newbie General 9 09-07-2009 08:08 PM
Why so loud? JeepinDoug Losi Mini-Rock Crawler 12 02-15-2009 07:50 PM
How loud? rizzle23 Newbie General 5 01-17-2006 07:48 PM
