Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Girlfriend Yeti....
Old 11-08-2015, 05:03 PM   #1
Default Girlfriend Yeti....
I just bought a stripped down (roller) RTR Yeti.
Now, this build will be cheapo. It's only to accompany my K-5 Blazer on scale trails, so no high-power combo, or heavy bashing!
I want to know what kind of upgrades I NEED to have..
It's a RTR version, all plastic.
It have the STRC knuckle and hubs.
I also have , not installed, Vanquish wheel hubs front/rear
Vanquish steering bearing upgrade.
I haven't open the transmission, but I guess it have metal gear in the transmission..
So, what are the needed upgrade..?
SilmarilS is offline   Reply With Quote
Old 11-08-2015, 05:06 PM   #2
Default Re: Girlfriend Yeti....
I have a SW3 combo with a 4600kv
Is it too fast, even with the smallest pinion...?
Or I could change it for a 35/27T brushed motor!
Old 11-08-2015, 05:16 PM   #3
i run a 5700kv with 16/64 gearing on 2s lipo and its pretty quick (more basher than crawler). i assume a 4600kv with similar gearing should be pretty good. enough speed to entertain yet still enough low speed to have fun on a scale run. I might be completely wrong though haha
honchoscaler is offline   Reply With Quote
Old 11-08-2015, 06:20 PM   #4
I would say the vanquish Bell cranks. With to other upgrades you have listed it will eliminate all slop in the steering.
JJ69chev is offline   Reply With Quote
Old 11-09-2015, 03:21 AM   #5
HD gears in the front and rear.
CamaroTom is offline   Reply With Quote
Old 11-09-2015, 09:37 AM   #6
Good... I plan to open the diff and tranny to inspect everything.. I will check for HD diff parts!
Old 11-13-2015, 12:20 AM   #7
In the process of changing the cheap flat black paint of the previous owner!
Old 11-13-2015, 03:03 PM   #8
Cool idea with painting the wheels two tone.
Hfrajuncajun is offline   Reply With Quote
Old 11-13-2015, 07:40 PM   #9
Thumbs up Re: Girlfriend Yeti....
x2 show off the results
Rdkill is offline   Reply With Quote
Old 11-14-2015, 09:24 AM   #10
Not the best masking around the rim, but hey, it's just a RC
Old 11-14-2015, 09:26 AM   #11
Just got out in the snow with the 4600 with a 11T pinon.. Not too fast, but no low end for scale trails.. Time to find another motor!
Old 11-14-2015, 05:12 PM   #12
I fun a castle 3800kv and that does good all around
Sent from my XT1042 using Tapatalk
mattehmer01 is offline   Reply With Quote
Old 11-14-2015, 06:43 PM   #13
not bad you won't even notice once there dirty
Old 11-14-2015, 08:06 PM   #14
The bright coloured orange spray painted rims look like destruction derby style.
Old 11-15-2015, 02:06 AM   #15
After my 1st run with my RTR, on 2S, the hinge pins for the a arms were pretzeled. I had to use a cutoff wheel to cut one of the pins so I could get it off.
So I put on one of these CNC Machined Aluminum Front Skid Plate/Hinge-pin mount for Yeti (Black)
I also replaced the plastic nut the pins screw into with an actual metal 4mm locknut.
I ran a set of stock hinge pins for a couple days until a set of these Carter Fab & Machine » Axial Yeti Hinge Pin Upgrade Kit showed up. When I swapped them out the stock pins were not bent in the slightest.
Since then I have run into stuff hard enough to break 3 stock knuckles and one knuckle carrier. The hinge pins are still not bent.
gman350 is offline   Reply With Quote
Old 11-15-2015, 04:53 AM   #16
I have the Carter pins as well. Excellent upgrade. I ordered three sets but probably won't need the other 2. Lol
mudbeast2 is offline   Reply With Quote
Old 11-16-2015, 09:03 AM   #17
Did you scuff the wheels at all, or just shoot them?
Old 11-16-2015, 10:19 AM   #18
Just shot them....
Since I don't plan on dumping money/time into this RC at the moment...
It's only to entertain the girlfriend..
Old 11-16-2015, 01:28 PM   #19
I bent the carter fab pins. IMO strong arm sleeves are a necessary upgrade. they have a page on facebook.
fr8cture is offline   Reply With Quote
Old 11-16-2015, 01:46 PM   #20
When I search FB for strong arm sleeves I get a page about sleeves for athletes
Girlfriend Yeti.... - Similar Threads
Girlfriend problem JRmudmanXJ Chit Chat 150 01-28-2011 08:04 PM
Ex Girlfriend Slowkrawl Chit Chat 24 11-24-2010 09:29 AM
the girlfriend pisseroffer rusty_86 Tamiya Clod Buster 10 09-01-2008 09:29 PM
girlfriend issues TLTCrawlin Chit Chat 87 08-28-2007 04:17 PM
