11-19-2015, 08:44 AM | #1 |
Rock Stacker Join Date: Nov 2015 Location: Lubbock
So I'v just about finished up putting the front suspension together last night but notices that the stock settings seems to incorporate quite a bit of negative camber. I know that I can make adjustments to correct this but wanted to make sure I didn't something backwards or upside down. both sides came out the same and I used a caliber to measure length. Last edited by THX_138; 11-20-2015 at 10:41 PM. |
11-19-2015, 08:46 AM | #2 |
RCC Addict Join Date: Aug 2012 Location: Philippines
| Re: Negative Camber with stock settings
Put the camber link on the inner hole of the caster block, not the outer one.
11-19-2015, 08:49 AM | #3 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
| Re: Negative Camber with stock settings |
11-19-2015, 08:52 AM | #4 |
That's what I thought too gbean but the instructions showed the outer hole for stock setup so I thought maybe I had something else off. Would have hated having it all built up just to realize I have to tear it down to flip a part. Figured it would be easier to ask at this stage then later. I'll make the changes tonight.
11-19-2015, 08:53 AM | #5 |
What position is the inboard end on?
11-19-2015, 08:59 AM | #6 |
I want to say bottom outside
11-19-2015, 10:13 AM | #7 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
When I followed the instructions I got the same results. I used my RPM camber gauge and lengthened the link. The instructions were not 100% correct. Seems there was another mistake in the instructions, but I can't recall right now. |
11-19-2015, 11:10 AM | #8 |
| Re: Negative Camber with stock settings There was a mistake about the front diff backwards at one point.
11-19-2015, 12:11 PM | #9 |
| Re: Negative Camber with stock settings Good to know, first kit build so I wanted to make sure I wasn't misinterpreting the instructions.
11-19-2015, 04:00 PM | #10 |
Pebble Pounder Join Date: Dec 2014 Location: Duluth
Double check the latest online download of the instructions. there were were several issues when it cames to link dimensions and grease locations. I know I went through my book and redlined everything to match.
Negative Camber with stock settings - Similar Threads | ||||
Hobbywing stock combo esc settings | Mick0004 | Electronics | 4 | 04-19-2015 09:17 PM |
Installed asiatees c hubs, now my camber is negative? | woodsman541 | Newbie General | 18 | 03-13-2015 06:17 AM |
Stock low voltage cutoff settings | P-J | Axial Yeti | 6 | 02-05-2015 10:28 PM |
Stock ESC settings | tcm glx | Axial Wraith | 5 | 02-09-2013 08:18 PM |
Rear negative camber? | frdtrkguy | General Crawlers | 1 | 12-30-2007 08:30 AM |
