02-10-2016, 07:46 PM | #1 |
Newbie Join Date: Jan 2016 Location: North Muskegon
| best first upgrad for yeti kit 1/10
i have a few extra bucks and just looking for some advice on the best first upgrade on the yeti kit version? i am sticking with stock wheels and tires for now. i am just wondering what all of you guys have broke first or replaced on your kit? Thanks!! |
02-10-2016, 07:57 PM | #2 |
Newbie Join Date: Jul 2015 Location: Lenoir City, TN
| Re: best first upgrad for yeti kit 1/10
I would say crawler innovations deuces wild foam. I use it with stock tires and wheels or you could get some rpm a arms. They are a cheap upgrade.
02-11-2016, 05:00 AM | #3 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
MIP driveshaft, FI spool, Axial aluminum motor mount are all nice mods.
02-11-2016, 05:07 AM | #4 |
Quarry Creeper Join Date: Jun 2013 Location: Australia
+1 on the MIP driveshaft. F1 spool is a good upgrade for when the rear locker quits. I'd be fixing the steering though - VP steering upgrades x3 - posts - bell crank - steering rack Sent from my iPhone using Tapatalk |
02-11-2016, 05:40 AM | #5 |
Rock Stacker Join Date: Jan 2016 Location: South Joisey
| Re: best first upgrad for yeti kit 1/10 +1 For Crawler Innovations Deuces Wild Foams (standard height #3003 for kit stock Wild Peaks)--If driving Yeti fast. They helped me prevent rollovers and it has a more planted feel now.
02-11-2016, 06:23 AM | #6 | |
| Re: best first upgrad for yeti kit 1/10 Quote:
Also the kit includes the steel posts and bearings for the steering unlike the RTR. Last edited by CamaroTom; 02-11-2016 at 01:33 PM. | |
02-11-2016, 07:29 AM | #7 |
Pebble Pounder Join Date: Oct 2011 Location: SLC
My first upgrades were rpm a arms, strc front toe block, and mip driveshaft
02-11-2016, 07:53 AM | #8 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
I'd say steering upgrades, too. STRC makes a great bellcrank set-up. Also consider aluminum castor blocks and knuckles. First thing I broke on mine. Maybe stronger hinge pins, too. Stocks bend really easily.
02-11-2016, 09:57 AM | #9 |
Quarry Creeper Join Date: Nov 2014 Location: WA
Cblocks and knuckes, mine broke in the first crash. (you may need adjustable turnbuckles) Steering you can put a bearing under the spring and keep it until you upgrade the whole system. The tire foams are also a fantastic and easy upgrade. The other drivetrain parts make more sense if you upgrade the motor/esc, otherwise they last for a good time. |
02-11-2016, 02:22 PM | #10 |
Pebble Pounder Join Date: Feb 2016 Location: canandaigua
| Re: best first upgrad for yeti kit 1/10 |
02-11-2016, 03:20 PM | #11 |
Quarry Creeper Join Date: Nov 2011 Location: In the woods
I upgrade as it breaks. I upgraded my entire steering assembly with a vanquish set up first, then an MIP drive shaft then jumped more snowbanks.
02-11-2016, 03:23 PM | #12 |
Quarry Creeper Join Date: Oct 2010 Location: Nashville TN
read the Stevec6r bulletproof yeti thread.
02-11-2016, 08:32 PM | #13 |
Newbie Join Date: Jun 2007 Location: Maine
02-12-2016, 06:30 AM | #14 |
02-12-2016, 07:58 PM | #15 |
Newbie Join Date: Feb 2016 Location: Sydney Aus,
depends on what you're doing, like crawlerrs will prefer weighted rims while speed nuts would prefer plastic, personally as a speed/basher i replace as breaks happen, first was rear axle bent, steering knuckle snapped(went boom racing as was cheaper than OEM once postage was done) and a-arm hinge-pins bent so went and did the traxxas threadless mod i would fix it when you break it so you will get a feel for what parts of your rig are taking your abuse and you can reinforce as needed but can also decide "no i WANT a weak point there so that i don't damage *insert precious part here* " just remember flex prevents snapping, cracking, shattering, and stripping of threads. i'm still fairly newbish but as an engineering student this is my opinion, note: opinion does not equal fact |
best first upgrad for yeti kit 1/10 - Similar Threads | ||||
Yeti kit or Wraith Spawn kit? | The Dark Knight | Axial Yeti | 3 | 09-25-2015 09:09 AM |
Axial Yeti XL Kit - My first kit build | vashan | Axial Yeti XL | 19 | 09-01-2015 04:46 PM |
