Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Motor getting hot
Old 07-15-2016, 10:33 AM   #1
Default Motor getting hot
Alright guys my motor is getting extremely hot. After 5 mins of running I can't even touch it.. is that normal ? Also I had a problem with the ESC getting hot and turn off.. I changed the pinion down a gear and that seem to stop..
Nickjblack89 is offline   Reply With Quote
Old 07-15-2016, 10:38 AM   #2
Default Re: Motor getting hot
Sounds like you just had it geared wrong. Dropping a tooth or two on the pinion should fix this as suggested.
byrnieman is offline   Reply With Quote
Old 07-15-2016, 10:54 AM   #3
I already have.. I think I dropped 2 on the pinion.. I just noticed it today I'll run it again I was kinda hard on the throttle testing today
Old 07-15-2016, 10:56 AM   #4
It always be "hot to touch".
Get a heat gun ($10-20) and make sure you are not over 180F
DenisLM is offline   Reply With Quote
Old 07-15-2016, 11:00 AM   #5
Ok will do... thanks
Old 07-15-2016, 12:00 PM   #6
What esc and motor? 2s 3s 4s? Definitely get a temp gun and go from there.
Ty1330 is offline   Reply With Quote
Old 07-15-2016, 02:30 PM   #7
Pull the motor and check for binding in the drive line. You may have a bad bearing. Also, if your gear mesh is too tight you motor will get hot.
YXLER is offline   Reply With Quote
Old 07-15-2016, 03:55 PM   #8
First thought I have is what servo do you have.... I run a Savox 1256tg, without the Castle external bec I had all your symptoms.......Solved it with a simple fix...after weeks of expert advice.
I learned to make sure end points set correctly, High "c" rated battery(I use 50 or 60c only), proper slipper adjustment .and gearing.
Castle who makes the axial motor /esc tell me not to exceed 180.
I have the RR slipper, the castle external bec geared 18/64 runs cool pack after pack here...ambient temp in the mid to upper 90's
mikemcE is online now   Reply With Quote
Old 07-15-2016, 04:17 PM   #9
I'll definitely take a look at everyone suggestions this weekend and let everyone know
Old 07-25-2016, 06:07 PM   #10
Get a castle fan for the esc and motor it should cool it down by 10-15 degrees
MM5150 is offline   Reply With Quote
Old 07-26-2016, 01:41 AM   #11
Keen to hear what setup you are running.
As for fans, they are more bandaids than anything. If you run so hot you need a fan, it's probably right on the edge of what that system can handle and is probably gonna turn into a paper weight sooner than later.
Motor getting hot - Similar Threads
Hot motor shiftauto Axial SCX-10 2 05-24-2016 12:31 PM
Hot Hot Motor bigdogs21ford Axial SCX-10 23 08-21-2014 03:30 PM
Hot motor !! SlownSteady Newbie General 6 05-12-2013 10:11 AM
How hot is too hot for the motor? Mr. Ed Losi Mini-Rock Crawler 4 06-13-2010 11:09 PM
motor temp - how hot is too hot? wicked4x4 Newbie General 16 03-18-2010 09:49 AM
