Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Axial 1/18 Yeti (and Yeti Score)
Old 12-14-2016, 10:20 AM   #221
Default Re: Axial 1/18 Yeti (and Yeti Score)
Originally Posted by redemon View Post
I mean its on their facebook page.
Fine, Ill do it.
"An exciting new contender in the smaller scale RC world was announced right before the weekend, and we couldīt resist the urge to instantly overpower it! Axial Racing's BRAND NEW Yeti JR. got the Castle treatment by installing a Mamba Micro X brushless system, adding a lot of spice in a small size!
Our range of 1/18th scale products can be found by following this link: http://www.castlecreations.com/en/mamba-micro-x
*Note that use of a specific pinion, for example the LOSB1261, is required for a proper installation"
Edit, they used the 4,100 for first tests.
Originally Posted by imthatguy View Post
Swap out the Nimh battery for a 2S Lipo and watch it come alive sir.
2s? Ill I have is 4s charged. We'll see.
Szczerba is offline   Reply With Quote
Old 12-14-2016, 11:11 AM   #222
Short and simple video I shot a few minutes ago behind work. We're expanding so there's no shortage of stuff to climb. Pardon the construction mess.
Yeti Jr with 2S 2200 25C LiPo.
https://youtu.be/MNQLdU6_gLc
My steering servo does not return anywhere close to center so it's a little wonky to drive.
Captain_Torquepants is offline   Reply With Quote
Old 12-14-2016, 11:33 AM   #223
For those of you who have one already, how's the build? Does the truck seem sturdy right out of the box or do certain parts feel flimsy?
curvedwallride is offline   Reply With Quote
Old 12-14-2016, 11:54 AM   #224
Mine showed up last night (been lurking on here a while). Initial thoughts:
1. It seems pretty sturdy. Suspension is well sorted for the price. I'm dubious as to the durability of the rear driveshaft / exposed bearing.
2. On 2S is has enough go for my purposes.
3. 2nd'ing the issue with the steering returning to center. It mostly doesn't...
4. When I started fiddling with the settings (first switch to LiPo, then went to turn on the drag brake) the receiver stopped responding. Working with Axial customer support now to sort it out (annoying to have an issue, but they are responding promptly to my questions).
All in all, I think it'll be a great little truck! It'll be getting a 3D printed Cherokee (XJ) body soon!
Cometcyclonemk is offline   Reply With Quote
Old 12-14-2016, 12:30 PM   #225
Thanks for the vid. I'd be happy with that power/speed. Too much more and the chassis may not like it without some major tuning.
cmbscx10 is offline   Reply With Quote
Old 12-14-2016, 12:39 PM   #226
No problem. There were no videos showing the top speed without slow motion and dubstep, so I made one. Quick, simple, done. I thought the same thing about the power / speed. As easy as it traction rolls, any more than this on 2S is going to be a real handful. I really like it the way it is on 2S and it should run for 40 minutes or more on a 2200 mAh pack. Gonna need a better servo as soon as possible though. Can't wait to get it into my crawler course when I get home.
Old 12-14-2016, 01:18 PM   #227
Did anybody order the SCORE/Trophy Truck version yet? Since I can't swing a Baja Rey right now, this little guy might be the backyard solution! I've personally had better luck with open wheeled 1/18 scale vehicles simply because the full bodied ones throw their roost inside the body which inevitably finds its way to/through the spur/pinion. I'm hoping the forward mounted spur and cover are enough to do the trick. On the flip side, I do tend to break fewer chassis parts on the full bodied cars (of any scale.) Also, are the TT tires as tall as the RR tires? I still need to wait to see what Santa brings, but I feel like there's money burning a hole in my pocket!
Edit: looks like the TT tires are 68x28 and the RR tires are 82x34
Edit again: 15t pinion on the TT, 10T on the RR, so even with the shorter tires, the TT should be faster out of the box.
TheLetterJ is offline   Reply With Quote
Old 12-14-2016, 01:45 PM   #228
what's the size of the stock servo?
DenisLM is offline   Reply With Quote
Old 12-14-2016, 01:46 PM   #229
Mine is the SCORE. Gears seem pretty well protected... I can't see how too much would be able to get in there.
Old 12-14-2016, 02:24 PM   #230
Thanks a lot Captain. I watched your video and just ordered one. Wife's going to be pissed but I'll wrap it and say its for my 2 year old daughter from Santa.
I have 2 2200 2s batteries that will be perfect for it.
Any thoughts on the servo? I'm ok with upgrading right off the bat.
You think any Mini will work?
blkbart00 is offline   Reply With Quote
Old 12-14-2016, 02:52 PM   #231
I would suggest checking out the servo saver first. 1/18 dromida had a ton of issues with centering and they were mostly related to a poor saver design that woundnt return to center. tighen up that setup, then if you kill the servo you will know its time for a new servo. that metal gear tactic should be miles ahead of the stock dromida one im used to in that scale.
StatGSR is offline   Reply With Quote
Old 12-14-2016, 03:07 PM   #232
I was curious of the tire size difference too. That TT is going to drag every where.
SCREAMER is offline   Reply With Quote
Old 12-14-2016, 03:19 PM   #233
Axial didn't splurge on the servo but that is to be expected. TSX106 Micro servo.
TowerHobbies.com | Tactic TSX106 Micro Servo High Speed with 25T Adapter
It doesn't say the dimensions but the other micro Tactic servos are all 23X12X27
Tactic Servos
This might be some option?
TowerHobbies.com | Hitec HS-5070MH Digital Ultra-Torque Feather Servo
It's just slightly bigger 23.6X11.6X29
Savox SH0256 Micro Digital Servo
Savox SH0254 Micro Digital Servo
Make perfect stocking stuffers
I wonder if there is room to fit a bigger Mini servo. I run the savox micro on my 1/24 losi and that has under 2" tires
Old 12-14-2016, 03:44 PM   #234
Yeah, got busy at work. I'll mess with that steering when I get home tonight. Looks like a standard 11 gram servo.
Old 12-14-2016, 04:21 PM   #235
Its actually the Metal Gear version based on Axials Web Site
TowerHobbies.com | Tactic Micro Servo Metal Gear 1BB with 25T Adapter
Old 12-14-2016, 04:22 PM   #236
Tactic Servos
Yeah a slightly bigger servo will be great, I hope this one fits:
Savox SW0250MG Waterproof Digital Micro Servo (29.5 x 14.0 x 32.5mm)
...may be a little too much, or the dremel may help...
Old 12-14-2016, 07:05 PM   #237
I tightened up the servo saver but it didn't help. That servo just doesn't center well, so it's out.
Two screws on the bottom, 4 screws to fold the battery box and body out of the way. That allows access to the one screw on the back of the ESC/RX/Servo unit. The servo is easily swapped at this point. I should have taken some pics but didn't, sorry. Hitec HS-65MG dropped right in. They included 21T, 23T, 24T and 25T servo saver adapters. Notice anything missing there? Yep, the 22T for Hitecs. Used a standard horn instead for now. I'll look for a Kimbrough at the LHS's on Friday. Returns to center every time now.
The steering bellcrank is actually one of the least sloppy systems I've seen in a 1/18 and the ball cups are strong too. They did a pretty good job up there.
Been running it around the yard and in the house chasing cats with it. Fun little Yeti!
Old 12-14-2016, 11:24 PM   #238
Both mine came in today. Ranthe Yeti for a minute but that was it. Definitely need to get some2slipos for them.anybody else finding any issues yet besides the servo?
axialshipp is offline   Reply With Quote
Old 12-14-2016, 11:37 PM   #239
I gave in, ordered one for my son for xmas, Thanks Axial, Xmas Shopping was all done and the you have to come out with this. I will have to test it, drive it, jump it, make sure its ok before you know. Don't want to give something questionable..
MaxxPain is offline   Reply With Quote
Old 12-14-2016, 11:42 PM   #240
Anybody got max. internal size of the battery Tray? What's the largest 2S anyones fitted in? I've got one on order but shipping to NZ takes ages and I'd love to have some small 2S batteries waiting for it.... any help would be appreciated. What exact battery are people running? Thanks guys?
TrilloThrillo110 is offline   Reply With Quote
Axial 1/18 Yeti (and Yeti Score) - Similar Threads
Axial yeti turned into a score? 1964yeti Newbie General 6 08-18-2016 12:47 AM
Upgrading Axial yeti score Naosis Newbie General 3 08-11-2016 05:49 AM
