11-22-2016, 06:16 PM | #1 |
Newbie Join Date: Oct 2016 Location: norfolk Virginia
| Pivot balls
How many and what size pivot balls would I need to get to replace all the plastic ones on my 1/10 yeti Sent from my SM-G920T using Tapatalk |
11-22-2016, 06:45 PM | #2 |
Pebble Pounder Join Date: Sep 2016 Location: SE Mo
| Re: Pivot balls
I used these on mine. https://www.amainhobbies.com/hot-rac...5emRoCZFHw_wcB Worked great. Sent from my Nexus 6P using Tapatalk |
11-22-2016, 06:58 PM | #3 |
Newbie Join Date: Jun 2015 Location: SoCal
| Re: Pivot balls
Word of advice, those HR balls look great and replace the STOCK yeti balls with zero issues. But if you have aftermarket balls, like say Vanquish steering links, you can't replace those balls. I tried using them in my VP links and they would bind like there was no tomorrow. |
11-22-2016, 07:26 PM | #4 |
Quarry Creeper Join Date: Jul 2013 Location: PA
| Re: Pivot balls
I used all traxxas revo style balls. I think it was about 20
11-22-2016, 08:25 PM | #5 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
| Re: Pivot balls
Use AXA1331 steel ball its a direct replacement for the stock plastic balls. I usually use traxxas balls in the stock axial rod ends with no problems and also use the AXA1331 in traxxas rod ends. Also if you use the axial part it will eliminate side to side slop because the axial balls are wider than traxxas and designed for axial parts.
Pivot balls - Similar Threads | ||||
cant find axial aluminum pivot balls | joshsmith512 | General Crawlers | 5 | 03-24-2016 07:38 PM |
NEW pivot balls from AXIAL | pro mod steve | Axial Yeti XL | 9 | 04-08-2015 08:29 PM |
plastic pivot balls | pro mod steve | Axial Yeti XL | 9 | 04-04-2015 08:44 PM |
pivot balls for losi shocks? | imbler2 | Newbie General | 4 | 03-14-2010 10:03 PM |
pivot mounts | trapt1011 | Tamiya Clod Buster | 4 | 11-04-2004 03:00 PM |
