Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: New SSD HD D60 Wide Conversion kit
Old 08-24-2017, 03:31 AM   #1
SSD
Default New SSD HD D60 Wide Conversion kit
You can now make your SSD HD D60 centered rear axle Yeti width:
Wide D60 Rear Axle Conversion Kit for Yeti
SSD is offline   Reply With Quote
Old 08-24-2017, 09:26 AM   #2
Default Re: New SSD HD D60 Wide Conversion kit
Sweet! I just got that axle and was considering some wider SLW hubs but this takes care of it... plus new axles!
are these the same length as the "diamond" axle shafts? just curious for when/if I bend them and need to replace or upgrade to the HD version.
Thanks for offering awesome aftermarket support for the YETI!
here is my D60... im running your scale knuckles too ;)
Shinchu is offline   Reply With Quote
Old 08-24-2017, 10:18 AM   #3
SSD
Yes the shafts are the same as Wide Diamond rear shafts. The shafts might not bend so easily in the plastic housing as it will flex a little. If you do need HD shafts with the Titaniium hexes then yes you can upgrade to SSD00084.
Old 08-24-2017, 10:24 AM   #4
Yashua
CREEPERBOB's Avatar
I cut Titanium axle shafts for this setup also ,
http://www.rccrawler.com/forum/axles...le-shafts.html
Keep these awesome parts coming ,
Bob
CREEPERBOB is offline   Reply With Quote
New SSD HD D60 Wide Conversion kit - Similar Threads
New SSD Wide Axle Kit for Yeti SSD Axial Yeti 28 02-19-2017 08:17 PM
New SSD D60 CMS Kit SSD Axial SCX-10 7 08-04-2016 04:13 PM
New SSD Rear Axle Shafts for D60 Wide Axle (XR) SSD Axial SCX-10 0 05-17-2016 10:51 AM
New SSD-RC Wide Rear Axle Kit for the YETI KRAWLR4life Axial Yeti 14 08-12-2015 08:42 PM
