08-21-2018, 09:41 PM | #1 |
Rock Crawler Join Date: Dec 2010 Location: tracy
| Internal spring shocks
Has anyone ran their yeti with internal spring shocks, either front or rear or both?. Looking at the yeah racing desert lizard 100mm for front. Curious to see if these kind of shocks can hold the weight of the yeti.... I use my yeti for mostly bashing and some bmx tracks and around the house. Pics also Sent from my Moto Z (2) using Tapatalk |
08-21-2018, 10:45 PM | #2 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: Internal spring shocks
In my humble opinion, internal spring shock’s performance is very limited. As you could not set their preload. For bashing purposes, I would suggest you to consider Traxxas big bore shocks or Pro-line power stroke. Cheers Sent from my iPad using Tapatalk |
08-22-2018, 07:21 AM | #3 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
Actually, with Desert Lizards at least you can set pre-load/ride height to some degree, although it's nowhere near as simple as coil overs with collars. Desert Lizards come with three different lengths of springs/four of each, so you can tune sag, droop, dampening and rebound with some flexibility anyway, and oil is basically optional. I'm running them on a Vaterra Ascender and an aluminum 10.1 and they work well. I don't think I'd put them on my Bomber, though...your experience with them on a Yeti may be less than stellar. Teng's recommendations were correct IMHO. |
08-22-2018, 07:27 AM | #4 |
RCC Addict Join Date: Jun 2016 Location: Germany
I have similar shox in the shelf for the old Playtron Bigfoot i Bring Back to Life. But i think they are not an option for the Yeti and bashing. Also 100 mm ist too long for the Front you will need 90 mm. Bigbore shox will serve you better as stated above. Have fun Send by my Pixel 2 XL with Tapatalk |
Internal spring shocks - Similar Threads | ||||
Internal spring shocks? | StomperCrawler | 1.9 Scale Rigs | 4 | 10-17-2017 12:22 AM |
Internal Spring Shocks | Jero | Tamiya XC/CC01 | 6 | 08-21-2014 11:01 AM |
internal spring shocks | perez62682 | Newbie General | 3 | 03-20-2010 01:39 AM |
internal spring shocks? | crawlerready | General Crawlers | 9 | 08-18-2005 08:20 PM |
