Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Servo Replacement Options
Old 09-20-2019, 08:30 PM   #1
Default Servo Replacement Options
I had a Hitec 7955TG that broke. Sent it in to Hitec and it isn't fixable. The offered a DS955 at a discount ($80).
Are there better options? I wouldn't mind something waterproof, but Hitec doesn't have one avalible yet.
Kit Yeti. Running 3s.
Caswell is offline   Reply With Quote
Old 09-21-2019, 01:33 AM   #2
Default Re: Servo Replacement Options
I'm running a Savox 1210sg, in mine, no issues. But now i would go with a HH shv500.
Gesendet von meinem Pixel 2 XL mit Tapatalk
magic_yeti is offline   Reply With Quote
Old 09-24-2019, 12:33 AM   #3
I have an Xpert 7701 in mine, waterproof (IP67 - certified for being submerged 1 meter for 30 minutes, if I remember correctly). Plenty of torque, never had an issue. Check it out at amain here.
Antsiranean is offline   Reply With Quote
Old 09-24-2019, 10:30 AM   #4
"Aminos" - Read generic Amazon, 35kg. Came with an aluminum clamp on horn for $37... likely not the best thing ever. But decent specs, hasn't blown up yet. But I also don't run super hard either.
Electrical Specification:
Operating voltage range: 5-7.4V
Operating speed ( 5.0V ): 0.1 3sec/60 degree
Operating speed ( 6.0V ): 0.12 sec/60 degree
Operating speed ( 7.4V ): 0.11 sec/60 degree
Stall torque ( 5.0V ): 29kg/cm
Stall torque ( 6.0V ): 32kg/cm
Stall torque ( 7.4V ): 35kg/cm
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
SlidePanda is offline   Reply With Quote
Old 09-24-2019, 11:31 AM   #5
Did they explain why it is not fixable? I know they discontinued the 7950th and now I’m not sure what my next best hitec option is.
odomandr is offline   Reply With Quote
Old 09-24-2019, 12:03 PM   #6
Moderator
I put a Pro Modeler 470 in mine. Overkill in every sense, just how I like it.
Jim85IROC is offline   Reply With Quote
Old 09-26-2019, 10:26 AM   #7
Another vote for the Pro Modeler 470. It's been great so far.
Rumpelhardt is offline   Reply With Quote
Servo Replacement Options - Similar Threads
Yeti Jr (RR and TT) Stock ESC/RX Issues and Replacement Options monkeyracer Axial Yeti 4 07-11-2017 03:46 AM
Yeti Jr (RR and TT) Stock Servo Issues and Replacement Options monkeyracer Axial Yeti 16 06-17-2017 07:47 PM
Replacement bearing options big_poppa49 Axial SCX-10 21 09-28-2016 07:54 PM
Replacement Chassis options? little squirt Losi Micro-Rock Crawler 2 08-01-2015 05:46 PM
Axial cvd starting to get some play...replacement options? jtessmer88 Axial Wraith 6 08-05-2014 05:28 PM
