03-01-2020, 09:27 PM | #1 |
Rock Stacker Join Date: Dec 2015 Location: Deep South
| Vanquish Rear centered currie rockjock?
Hi - I have the early edition of the Vanquish currie centered rear rockjock axle for my Yeti 1/10. I have a Locked up RC Locked up RC - FI Spool locker. My Currie rear didn't come with the larger bearing for the pinion it uses the stock sizes 5x11x4mm one on the inside then slide the pinion shaft through and one on the outside where the drive shaft hooks up. My question is what holds the pinion from moving around? (frontwards and backwards ) I am building the rear without my yeti here so maybe that is the problem.... |
03-01-2020, 11:43 PM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Vanquish Rear centered currie rockjock?
The pinion movement can be limited if you shim it. And the drive shaft limit it too, it's needed to shim correct. Hope that helps. Gesendet von meinem Pixel 2 XL mit Tapatalk |
03-02-2020, 10:10 AM | #3 |
| Re: Vanquish Rear centered currie rockjock? |
03-02-2020, 11:57 AM | #4 |
Don't forget to shim both sides. Gesendet von meinem Pixel 2 XL mit Tapatalk |
03-03-2020, 09:15 PM | #5 |
08-02-2020, 12:32 PM | #6 |
Newbie Join Date: Feb 2020 Location: NYC
How do you like the Center Pumpkin Currie RockJock70 on your Yeti? Do you need to still run lockouts?
08-27-2020, 10:12 PM | #7 |
Newbie Join Date: Jan 2015 Location: Weston,Florida
I like it. I run that on my current Yeti
Vanquish Rear centered currie rockjock? - Similar Threads | ||||
Vanquish currie rockjock axels | NitroDarwin | Axial SCX10 II | 266 | 03-05-2020 05:27 PM |
Vanquish Currie Rockjock 70s on GOM | RockStacker | G-Made Crawlers | 32 | 09-01-2018 08:52 PM |
Rear spool for Vanquish Currie Rear Centered Pumpkin | Deadbydawn | Axial Yeti | 4 | 02-06-2018 10:49 AM |
Vanquish Currie RockJock Axle | fatroofus | Newbie General | 7 | 01-16-2016 11:31 AM |
