11-12-2011, 08:31 AM | #141 |
RCC Addict Join Date: Mar 2008 Location: SSF
12-05-2011, 12:46 AM | #142 |
Pebble Pounder Join Date: Apr 2011 Location: australia
| Got them today awesome finish . Doug you are a legend . Thanks Shaun in OZ |
12-19-2011, 07:02 PM | #143 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
I can't find the price. Am I blind? Thanks.
12-19-2011, 07:08 PM | #144 |
| Re: JeepinDoug's stand off shock ball mounts, 5mm and 6mm
In post number 1. I just highlighted it in yellow. |
12-19-2011, 07:13 PM | #145 |
Odd for some reason on my phone using tapatalk it's cut off and I can't see it. I'll have to log in and check. Thanks
01-04-2012, 12:50 PM | #146 |
Quarry Creeper Join Date: Nov 2011 Location: Maryville
What are folks using at the axle end to compensate for the offset up top? I'm especially interested in being able to flip my shocks over at the same time...if someone had a list of the parts needed to do so with the stock shocks, that would be awesome. Thanks, Chris |
01-18-2012, 01:58 PM | #147 |
Just ordered 4 5mm for my traxxas shocks. Thanks!
01-18-2012, 01:58 PM | #148 |
What's the reason for running traxxus shocks on a LCC? And, what are the shock part numbers? Thanks, Chris |
01-19-2012, 03:47 PM | #149 |
Big bore shocks are smoother. But some guys love there losi shocks. The big bores come in different sizes. Part number depends on the length you need for your rig. Start reading more to find out what you need
01-23-2012, 08:11 PM | #150 |
K thanks. Chris |
02-09-2012, 08:19 PM | #151 |
Pebble Pounder Join Date: Aug 2004 Location: east of KNOXVEGAS ......
payment sent for a set in 6mm ..... thanks . |
02-10-2012, 07:52 AM | #152 |
Rock Crawler Join Date: Nov 2008 Location: Roseville,Ca
What size would fit the proline scaler shocks 5mm or 6mm?
02-18-2012, 09:22 AM | #153 |
| Re: JeepinDoug's stand off shock ball mounts, 5mm and 6mm |
02-25-2012, 05:18 PM | #154 |
Newbie Join Date: Oct 2008 Location: Switzerland
Just ordered 5mm for my traxxas shocks and international shipping. Thanks Oli |
02-25-2012, 06:14 PM | #155 |
Quarry Creeper Join Date: Oct 2008 Location: In the basement...
5mm do not fit the Proline Powerstrokes - Ordering 6mm now
03-03-2012, 07:42 PM | #156 |
Sadly the 6 don't fit either!
03-04-2012, 10:53 AM | #157 |
I use 6mm on my power strokes , tight fit , you may need to dremel them down a little . Sent from my stupid iPhone using Tapatalk |
03-04-2012, 10:48 PM | #158 | |
| Re: JeepinDoug's stand off shock ball mounts, 5mm and 6mm Quote:
First I would try to ream the hole for the larger 6mm ball. You could also use a ball cutter in a dremel and carefully cut the center of the ID of the shock end. The last thing to try is mount the ball mount to a long screw and fasten it with a nut. Then hole the screw in a drill chuck/press. With fine grit paper, lap the ball diameter down to fit. The ball/sphere on the mount is not a perfect sphere and a little sanding will get it where you want it. If the Powerstrokes are like the SCX-10 shocks, the ball measures 5.71mm (.224. I make these right around .230"/.231", just under 6mm. | |
03-05-2012, 07:57 AM | #159 |
Paypal sent for 6mm set.
03-05-2012, 08:02 PM | #160 |
Newbie Join Date: Jan 2012 Location: sacramento
Payment sent for a set of 6mm for Losi 4" crawlers Thanks |
