Go Back   RCCrawler Forums > Vendors > Vendors Market > Chassis and Suspension
Thread: Wraith Links Aluminum, Titanium and Delrin
Old 05-17-2013, 08:54 AM   #41
Default Re: Wraith Links Aluminum, Titanium and Delrin
Originally Posted by dots36 View Post
I bought your links earlier for my honcho and now working on my scx10 dingo. Can you make me upper links for the front and rear on my Dingo. 4 link with rod ends. If so let me know how to proceed.
Don Fryman
this is not the first time i have been asked this question. let me look into it...
thx!!
Blue Monkey RC is offline   Reply With Quote
Old 05-17-2013, 09:59 AM   #42
Trailing Arm Rear Suspension for your Wraith
Old 03-05-2014, 01:06 AM   #43
TWO questions....
1) I'm considering Ti Links for both XR10 and Wraith. I had heard that they might be available in 1/4". Also for the steering links on the Wraith. True?
2) On your Wraith Lower Links....they are bent or hi clearance. The stock ones are straight. Since they are bent, does it expose the drive line? I want to use the MIP's, but I'm thinking the drive line might get hung up with the bent lowers. True or false?
Thanks....
Originally Posted by Blue Monkey RC View Post
Here are our NEW Ti steering links for Wraith and Ridgecrest... and more pictures of the suspension linkage. 7 sets currently in stock ready to ship, more in process.
RockKook is offline   Reply With Quote
Old 04-17-2014, 06:07 AM   #44
sorry for the slow response i'm going thru my old threads.
in the second to last picture you posted you can see the amount of driveshaft exposed.
if you prefer straight links i can do that. that's easy
as far as 1/4" links... yes we can make them and do make them HOWEVER i strongly urge you to reconsider. 3/16" is massive overkill. 1/4" is just adding too much weight to your suspension. this is a case where bigger is NOT better... its worse.
HTH
Old 05-25-2014, 02:51 PM   #45
Any reviews or users of the delrin steering? I keep bending my home made 3/16 stainless rod steering tie rod and am considering the delrin since it'll deflect rather than bend
Richterat83 is offline   Reply With Quote
Old 05-27-2014, 11:50 AM   #46
one of my local friends/product testers broke one about 2 years ago. i beefed up that area and have not had any other breakages. however if you bash your truck a lot I would highly recommend titanium. you will not bend a 3/16" 6al4v titanium link (while mounted on the vehicle).
the delrin links are more of a "finesse driver" link not meant to be driven full throttle into obstacles.
Old 05-27-2014, 11:55 AM   #47
It's an Ultra4 2.2 Trophy class on a Pro4, so it'll be hitting rocks at speed every lap. The stainless isn't holding up, so the Ti should be better?
Old 05-27-2014, 12:03 PM   #48
not typically but the 6al4v is really tough stuff. what type of stainless did you use? different alloys are made so you can bend and form them easier.
all my parts have a lifetime warranty and i have never had anyone bend or break a titanium link. just sayin.
Old 05-27-2014, 12:27 PM   #49
10-4 on that, i'm running your dual servo CMS and panhard setup and love it
Looks like next paycheck gets a tie rod/drag link from you.
Oh, and do you offer custom lengths for the drag link? I'm wanting to get a D-lux ultra4 servo mount/axle truss and i'm not sure what length is needed for that.
Old 05-27-2014, 12:42 PM   #50
we are almost ready to start making custom length links again. i think in about 2 more weeks we'll be in a comfortable position and i'll put something online for easy ordering.
FYI we're going to offer custom length turnbuckles around the same time.
Old 05-27-2014, 12:51 PM   #51
*** The NEW Blems are in !!!***
i've got a dozen or so of the 4130 spools available. they have 6 holes instead of 4 due to a machining error and if using aftermarket gears you will have to open up the center hole a bit (approx .0005" larger).
these issues are enough to make the parts blemished but will not affect performance in any way.
rock bottom price of $15 each plus $5 shipping. email sales@bluemonkeyrc.com before they are all gone.
Wraith Links Aluminum, Titanium and Delrin - Similar Threads
Steering/Suspension Aluminum, Titanium, Delrin links. Custom made Erik D_lux Chassis and Suspension 72 07-31-2020 05:28 PM
Delrin links or Aluminum eggie Redcat Crawlers 7 05-11-2010 12:51 PM
Delrin or Aluminum links azrael_nite Newbie General 11 01-25-2008 04:31 PM
You may edit your posts
