Go Back   RCCrawler Forums > Vendors > Vendors Market > Chassis and Suspension
Thread: Wraith Electronics box
Old 01-20-2013, 10:53 PM   #81
Default Re: Wraith Electronics box
name/screen name
1.robert chinchilla/ robchinchilla
2.rhett cale dieselmudder front electronics box
3.Chris / Baja Bandido for rear drop and cover
4.
5.
6.
7.
8.
9.
10.
Count me in! Any ETA on these?
Chris
Baja Bandido is offline   Reply With Quote
Old 01-21-2013, 09:44 AM   #82
Looking good!
1 rear drop box & 1 flat cover please.
Dostradamas is offline   Reply With Quote
Old 01-21-2013, 10:01 AM   #83
Alrighty gang, we're going to augment the waiting list so theres no confusion when we PM everyone for availability and fill orders
Name/Screen name/Item(s) you want ie; front box, rear drop box with or without flat cover.
1.robert chinchilla/ robchinchilla. Order sent 1/17
4.
5.
6.
7.
8.
9.
10.
Please copy and paste this list when you add your name to the list so we can keep track of everyone. We get ALOT of PM's to plow thru each day on top of running the shop and this will keep everything in line, thank you guys for your understanding
The Crawl Space is offline   Reply With Quote
Old 01-21-2013, 10:05 AM   #84
Originally Posted by gbean View Post
Put me down for a rear cover!
Just add your name to the list and we'll put your name on one once they come in
Originally Posted by spankbomb View Post
Curious, will a Wraith on 1.9s and SCX10 axles have clearance issues with the rear drop-in box? Will pricing be similar to the front or more?
Thanks,
Jon D.
There shouldn't be any clearance issues with the rear box. It will sit on top of the "double T" crossbrace where the stock battery tray is, which will need to be removed for installation of the rear drop box
Old 01-21-2013, 04:29 PM   #85
4. Shawn / Dostradamas 1 rear drop box & 1 flat rear cover
5.
6.
7.
8.
9.
10.
I am in.
Old 01-21-2013, 05:20 PM   #86
4.
5.
6.
7.
8.
9.
10.
Put me down for a rear box with cover also.
Sent from my C771 using Tapatalk 2
dieselmudder is offline   Reply With Quote
Old 01-22-2013, 03:05 PM   #87
4.brian pratt/madtinner rear drop and cover
5.
6.
7.
8.
9.
10.
names on the list
madtinner is offline   Reply With Quote
Old 01-23-2013, 12:59 PM   #88
Order sent 1/17
2.rhett cale dieselmudder front electronics box. Rear box w/ cover.
5.
6.
7.
8.
9.
10.
List updated 01.23.13
As soon as we get the rear drop boxes from Michael we will be contacting everyone on the list and shipping asap
Old 01-23-2013, 06:11 PM   #89
how much for a rear box and cover?
chopan84 is offline   Reply With Quote
Old 01-24-2013, 09:14 AM   #90
Once Michael is done with the final product we'll post up the price
Old 01-24-2013, 10:57 AM   #91
got my front box in the mail and installed...
its nice, but it didnt fit with my vp panhard bar kit..
had to cut the front off to get it to fit..@3mm off front of box
had to trim the excess off of it to get it to fit down in chassis so i could run my 3s 4500mah
ROLANDROCKSHOP is offline   Reply With Quote
Old 01-24-2013, 11:08 AM   #92
Some pics of your front end showing the box & panhard would be helpful for many (not me Dinky S ohhh yeah.) There have been a few questions on this exact issue (will it work with my panhard?)
If you can get a pic or 2 up please do.
Old 01-24-2013, 11:17 AM   #93
added 2 photos to my post...
if you had the vp servo mount moved further forward it looks like it would work but still be tight..
i cant or dont want to move it forward because of the panhard bar,it would hit the truss smack dab in the center..
hitting those servo mount tabs..thus limiting my upward travel.
Old 01-24-2013, 11:33 AM   #94
Thanks!
Old 01-24-2013, 04:01 PM   #95
Mine fit with the servo moved forward a little.
Old 01-24-2013, 04:20 PM   #96
Old 01-24-2013, 05:05 PM   #97
Yea guys, I did not consider the panhard mod because it seemed like not too many people have done those (I could be wrong too) as I just have not seen that many rigs with them.
As war as getting rid of that beveled corner, I could have another version of that as well to fit larger batteries.
I did that to make the box not stand out when looking at it from the side and not to have any tire clearance issues.
Flying Dutchman is offline   Reply With Quote
Old 01-24-2013, 05:21 PM   #98
I think those beveled corners are perfect!
I used that surface to attach my inner fender in the front.
I used this tray to force me into a smaller 2000mah 2s pack & now it all fits under the hood in a solid bowl & the foam under the hood seals it up nicely
Old 01-25-2013, 11:54 AM   #99
Thank you for posting pics, I talked to a couple guys around here that run the VP CMS and they didn't have a clearance issue, but I think its because they got the box and then the CMS kit and adapted the CMS to the box position. As far as battery placement and size, the box does limit the user to the size of battery and running gear and unfortunately I can't help with that but think you came up with a good way of making it work.
Michael, more people are getting into the chassis mount and panhard set up and like a said above, guys are getting the box first and then making the CMS kit work around it.
I think the beveled corner was a good idea and one of our customers that runs bigger batteries heated the corner with a lighter and pushed the battery into the plastic and it molded around the battery it fit well.
All in all, the front of the Wraith can be difficult to work with when placing large batteries and running gear, light and winch controllers, etc, etc. God knows how much time its taken me in the past when building customers rigs and getting EVERYTHING under the hood and into the stock RX box
Nice, I do like this quick and easy mod, thanks for the pic
Old 01-25-2013, 11:58 AM   #100
I joined the Band!
Will this work with the vanquish cms setup?
TNCrawler is offline   Reply With Quote
Wraith Electronics box - Similar Threads
Electronics box for Axial Wraith Swass Axial Wraith 1 11-21-2012 10:04 AM
electronics box for wraith couch Axial Wraith 22 12-20-2011 05:32 AM
lowering the body and the electronics getting the electronics in a waterproof box m1009cucv Axial SCX-10 15 10-01-2011 07:45 PM
You may edit your posts
