08-31-2015, 11:58 PM | #1 |
RCC Addict Join Date: Nov 2008 Location: Central, WA
| ToyZuki's angled skid scx10 chassis ToyZuki's Fabrication is excited to release a cool new upgrade for the scx10 This is designed to bolt up to all your stock components and therefore should work with all your aftermarket components as well. These are made from a composite called G10. Supposed to be stronger than carbon fiber. Here's a list of what has changed from a stock set of rails. Angled skid to promote fwd movement when high centered Integrated shock hoops for strength Integrated servo and servo winch mounts Raised front rail for more drag link clearance and better approach angle Added link risers for suspension tuning and allowing you to run a flat skid (working on that too) Added shock mounting holes to adjust your ride height For display purposes this was mounted to a box stock rig to show how it works, but I have a few build threads with earlier prototypes showing it with bent rear links, servo mounted to the chassis, ToyZuki motor mount, soon to be released ToyZuki transfer case. I've been beating on these rigs for over a year now with great results! $60 shipped in the continental U.S. PM me for international shipping quotes Also still have these available in aluminum. Have had a few requests for steel too. If I get enough interest I will cut a batch in steel, but their 13.5oz in steel. We will have to get a head count and discuss something thinner than .125 Last edited by ToyZuki; 09-01-2015 at 12:24 AM. |
09-01-2015, 12:02 AM | #2 |
| Re: ToyZuki's angled skid scx10 chassis
Saved
09-01-2015, 12:02 AM | #3 |
for
09-01-2015, 12:02 AM | #4 |
later |
09-01-2015, 12:08 AM | #5 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
Liked and subbed. Sent from my Nexus 5 using Tapatalk |
09-01-2015, 02:25 AM | #6 |
RCC Addict Join Date: Aug 2005 Location: SoCal
I think its time to build a new C3! |
09-01-2015, 03:03 AM | #7 |
| Re: ToyZuki's angled skid scx10 chassis |
09-01-2015, 05:59 AM | #8 |
09-01-2015, 07:45 AM | #9 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
I'd think in steel you could get away with 14 maybe 16 gauge. I will be watching though. I'm in the same boat, I have 2 builds going and would like a new C1 before Nats. Not sure how much I'll be able to actually drive there though... |
09-01-2015, 09:04 AM | #10 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Plexi----------------------1.8oz Delrin/Alum hybrid------ 2.5oz G10-----------------------3.6 oz Aluminum ----------------4.5 oz steel---------------------13.5 oz G10 is black, lighter, has the same rigidity if not more than the Aluminum and most of all sexy Disclaimer: So Toyzuki doesn't get bombarded with requests---Only alum and G10 are currently available, the others were R and D. Last edited by hotwheels000; 09-01-2015 at 05:43 PM. |
09-01-2015, 12:01 PM | #11 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
I have a C3 in the works and a C2 I never did a build thread for with the Ally Chassis. The C2 pulled 3rd in Class3 at the 2014 RC4WD Scale Challenge.
09-01-2015, 12:10 PM | #12 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
Very nice work.I to have some future project this winter..... One particular rig is a 6x6 tow rig any thoughts on making chassis rails for a 6x6. |
09-01-2015, 05:44 PM | #13 |
I edited the post on weight. It should have been ounces, not grams.
09-01-2015, 06:06 PM | #14 |
09-01-2015, 06:08 PM | #15 |
| Re: ToyZuki's angled skid scx10 chassis I did one out of .125 mild steel and it was over 13oz of sprung weight. I'll make a few more out of thinner material and see what happens. |
09-01-2015, 09:39 PM | #16 |
Quarry Creeper Join Date: Sep 2013 Location: post falls
As always another awesome product ben
09-05-2015, 06:58 AM | #17 |
Rock Stacker Join Date: May 2013 Location: Brownsburg, IN
Can you show a pic with the tranny installed and how it affects the drive shaft angles? Looks like it would help the front but increase the output angle even more on the rear.
09-07-2015, 09:28 AM | #18 |
Pebble Pounder Join Date: Mar 2012 Location: Port Angeles
Here's a pic of mine running MIP shafts with the 5mm extended out drive on the trans side. WB is set at 12.3"
09-07-2015, 04:13 PM | #19 | |
| Re: ToyZuki's angled skid scx10 chassis Quote:
Thanks for the pic yotapower! | |
09-09-2015, 05:16 PM | #20 |
Quarry Creeper Join Date: Oct 2012 Location: Cashmere (central WA)
Checked out the carbon ones last weekend at East Vs. West scale comp, they look great - i already have a aluminum one on my class 1 build and it's great.
