03-07-2020, 05:14 PM | #1 |
Newbie Join Date: Mar 2020 Location: Memphis
| lift kit
How do you build a lift kit for a rc truck because this is for a traxxas rustler xl-5 and how hard is it?
03-07-2020, 05:55 PM | #2 |
Newbie Join Date: Aug 2019 Location: Boston
| Re: lift kit |
03-07-2020, 06:04 PM | #3 |
| Re: lift kit |
03-07-2020, 06:45 PM | #4 |
| Re: lift kit |
03-07-2020, 06:47 PM | #5 |
| Re: lift kit |
03-07-2020, 09:10 PM | #6 |
| Re: lift kit |
03-07-2020, 09:11 PM | #7 |
| Re: lift kit |
03-08-2020, 08:17 AM | #8 |
| Re: lift kit
im not familure with this rig but some simple shock keys should do the trick if not you can make some out of aluminum about 1/8th thick you can pick it up at just about any hardwere store then something to cut the aluminum like tin snips or heavy duty sissors and cut slow the shock keys will cost less than the tin snips and proba ly about the same as the aluminum sheet badicly you just droping the upper shock mounting points down to get more lift or buy longer shocks |
03-08-2020, 09:54 AM | #9 | |
| Re: lift kit Quote:
Which is the most expensive and hardest | |
03-08-2020, 01:12 PM | #10 | |
| Re: lift kit Quote:
As do Most expensive and easiest. Most easyiest would be to buy the lift kit if one is avaliable, it would probably be the most expensive option. Depending on your skill level, making one could be easy, It could also be the most expensive depending on what tools you have. | |
03-08-2020, 02:29 PM | #11 |
| Re: lift kit |
03-08-2020, 03:02 PM | #12 |
| Re: lift kit
The Traxxas Rustler is a very basic 2 wheel drive stadium truck and is not easily lifted. This forum has much more to do with rock crawlers and not so much about what you have. It does have some parts in common with the Traxxas Stampede, which is much more of a "lifted" style truck. I did a quick Google search on "traxxas rustler to stampede conversion" and found lots of forum posts and even YouTube videos on it - that is by far the best way to go. Traxxas Rustler and Stampede parts are super cheap because they have both been around forever, and you can even build a stronger than stock Stampede by using RPM brand stuff wherever possible. The Stampede also has a ton of aftermarket bodies available to totally customize your truck. Here's an example YouTube link: A picture of a Stampede: |
03-08-2020, 03:23 PM | #13 | |
| Re: lift kit Quote:
Last edited by JatoTheRipper; 03-08-2020 at 03:29 PM. Reason: Refrain from quoting photos and videos | |
03-08-2020, 03:23 PM | #14 | |
| Re: lift kit Quote:
That was a very thoughtful, and well meaning post. Wait for the OP’s reply.... Sent from my iPhone using Tapatalk Last edited by JatoTheRipper; 03-08-2020 at 03:30 PM. Reason: Refrain from unnecessarily quoting photos and videos | |
03-08-2020, 03:26 PM | #15 |
| Re: lift kit |
03-08-2020, 03:29 PM | #16 | |
| Re: lift kit Quote:
are there any videos or links for the suspension swap to make the rustler lifted? | |
03-08-2020, 03:31 PM | #17 |
| Re: lift kit |
03-08-2020, 03:33 PM | #18 |
| Re: lift kit |
03-08-2020, 03:51 PM | #19 |
| Re: lift kit
I think you're all fighting a losing cause here. He asks questions, but doesn't seem to do anything to help himself. His username has similar history on other forums.
03-08-2020, 04:05 PM | #20 |
| Re: lift kit
You can lead a horse to water, but you can't make him drink... I'll close my involvement in this thread by stating that I owned a Rustler (my 1st R/C ever!) many, many years ago - and a few years later added a Stampede to the mix. The Rustler handled much better at high speed, but the Stampede could run in taller grass and would pull wheelies on demand. Use Google to find videos on how to help yourself and to find OTHER forums (there are many that talk about Rustlers, this isn't one of them) for any answers I haven't helped with. I've outgrown such things and only have crawlers now - my only non-crawler is an 1/8th scale Team Associated DB8 Desert Buggy (40mph+!) that I keep forgetting to box up and sell. |
lift kit - Similar Threads | ||||
Lift kit | indybama | Axial SCX10 II | 2 | 09-03-2018 04:18 PM |
Has anyone done the lift kit? | gator_08 | Traxxas TRX-4 | 13 | 07-01-2018 06:46 PM |
Lift Kit or Droop Kit? | LBrown867 | Axial SCX-10 | 6 | 04-28-2014 11:42 PM |
lift kit | BLOODBANE | Chit Chat | 9 | 02-12-2014 06:55 PM |
Lift Kit ? | TOMMY RAINS | Traxxas Crawlers | 11 | 04-02-2006 11:41 AM |
