09-03-2007, 09:57 PM | #41 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Anybody ever try the brake fluid besides me....No chit it eats paint....thats why it works. Like I said be carefull not to use to much,you will be amazed how easy it is to do,and as long as your paint isnt already showing primer you should be fine.... |
09-04-2007, 12:32 PM | #42 |
Rock Crawler Join Date: Jun 2005 Location: Safety Harbor
I 2nd the 3M polishes.I've used their mico polish on a few cars with faded paint with great results.Try to find a polisher/grinder that has a variable speed.And be VERY careful around the edges and ridges.REAL easy to burn thru those.
09-04-2007, 12:36 PM | #43 |
if you used rubbing compound youll need to go back over it with polishing compound or a decent wax to buff the shiny back in it. rubbing comoound is usually way too course for cars you basically scuffed the surface, will actually REMOVE the shine from a modern two stage paint car. on my old 86 camaro with single stage, i used "nu finish" with very nice results. you can get it at pretty much any autoparts store, probly walmart too. its cheap. Last edited by STANG KILLA SS; 09-04-2007 at 12:39 PM. |
09-04-2007, 10:05 PM | #44 |
So far rubbing compound with a wet rag by hand is yeilding the best results. I may have to do the whole car 2 or 3 times but I think it will be red again!
