![]() | #61 |
Quarry Creeper ![]() Join Date: Dec 2012 Location: Eastern Tennessee
Awesome thread,should be a stickey! ![]() ![]() |
![]() | #62 |
Newbie Join Date: Dec 2012 Location: Fuquay
Hey guys! Just ordered a SCX 10 Jeep Rubicon an went to the Hobby shop today and picked up a Venom Pro Charger while i was there and had them to order a 2C 5800 mah Lipo and after reading on this thread wonder if i did right or not???? Ill be crawling some and playing around on trails,etc. an sometimes it maybe setting around a week or so. Any Comments???? Thanks
![]() | #63 | |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
| ![]() Quote:
![]() | #64 | |
| ![]() Quote:
As mentioned, you may get chargers or batteries cheaper elswhere, but I also like to support my LHS so I can just, "walk in" and buy something on Saturday so I can be running for a comp Sunday. ![]() ![]() As to the Venom ProCharger, we have 3 (one is a ProCharger Plus), all are a few years old. Yes, there are cheaper chargers outh there as well as units that charge more than 1 pack. Our chargers run on AC or DC, come with multiple plug-in harnesses and a balance board. Other units have you spend more money to get to the same point, thus the price difference lessens. ![]() As to battery size, sometimes it's better to have 2 smaller packs than 1 large pack. Partly since if you kill a pack, you still have another. I use www.CheapBatteryPacks.com for my packs. Never an issue and lots of options for a reasonable price. Gens Ace and other seem to have a decent following for a lower price. | |
![]() | #65 |
Thanks so much for the info.....
![]() | #66 | ||
Rock Stacker Join Date: Dec 2012 Location: Fremont
| ![]() Quote:
But now I want a 3S Turnigy nano Tech and I am clueless about what mah to or c rating to buy. I'm going to buy 2 batteries and I want them to last a full days crawling for an event like the G6 hammers. I have some 5000 mahs 2S that will probly last all day but others crawlers say they are too big.. I see you guys using 2000 mah or so but that seem like it will not last to me, especially on 3s. So what do i need to crawl a scx10 all day on 3s using a stock esc and 27 turn motor for now and upgrading to a Holmes Hobbyesc and 27-35 turn later???? Thanks in advance for any help!! ![]() Last edited by 5VoltDetonator; 01-15-2013 at 08:54 PM. | ||
![]() | #67 |
RCC Addict ![]() Join Date: Jan 2012 Location: Sweden
Exactly how much you'll need is impossible to foresee. - A higher voltage battery contain more energy at the same charge capacity. If you keep driving basically at the same speeds as before a higher voltage battery will last longer. - Higher voltage provide for higher top speed and power usage, which allows you to drain the same capacity faster if you run at the same throttle levels. As I've understood it a typical full day's trail crawling consist of less than 50% actual driving time. Actual driving is also typically done at a fairly slow pace, even if much higher speed is available. The best battery arrangement I've seen in a SCX10 is to have a two battery saddle pack style mount with the batteries on the plates between the front and rear wheels. If you pick batteries of a physical size that fit nicely in there you'll do very well! (Either a pair of 3S in parallel or a pair of 2S in series, provided your ESC can handle 4S.) |
![]() | #68 | |
| ![]() Quote:
![]() | #69 |
Quarry Creeper Join Date: Dec 2011 Location: The land of snow
I run a pair if gens ace 4000mah 2s batteries in parallel in my scx. It has a cc sct esc and a 45t integy motor. It's a fairly light truck as far as a scaler goes and I never did manage to run out of power. If I had to guess I would say the truck was good for 4-5 hours depending on driving conditions
![]() | #70 | |
| ![]() Quote:
![]() | #71 |
Rock Stacker Join Date: May 2007 Location: Ft Stewart
Some good info. Now where is best place to pick up a Nimh battery and charger for a Losi mini?
![]() | #72 |
Quarry Creeper Join Date: Aug 2015 Location: canton,oh
| ![]() ok im studying and reading about lipos but still questioning if i for crawling i should get 1p or 2 p? i have a a variety of crawlers so which instance would i want a 1p and when would a 2p be better? thanks in advance....and i see this is old thread thought if posted and answered here would keep good info alive and together ![]() |
![]() | #73 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
2p is pretty uncommon these days. Id stick with 1p
![]() | #74 |
Newbie Join Date: Nov 2015 Location: Mountain Home
I have an RS10-XT that came with a 7.2v 1800aHr battery. I am told that I can get a performance boost using a 9.6v 3800aHr battery. Will the higher voltage cause any problems with the esc or motors?
