Thread: Castle Link on a Mac using Boot Camp
Old 01-19-2008, 04:03 AM   #1
Default Castle Link on a Mac using Boot Camp
I was able to run the castle link software on my intel based mac using boot camp and windows XP. Now, I don't have to use my wife's dell to mess around with my Mamba Max. Just a heads up for all those mac users.
kawika is offline   Reply With Quote
Old 01-19-2008, 07:00 PM   #2
ahha.. I'm using Parallel to with my XP to tweak my Mamba Max, Mamba 25, castle BEC
I was surprised that emulation took USB...
jmizoguchi is offline   Reply With Quote
Old 01-19-2008, 08:57 PM   #3
i'm using VirtualPC on my power PC based G5, and am barely able to use Castle Link. as soon as i plug the USB cable in, it gets weird. still works, but barely.
ClodMaxx is offline   Reply With Quote
Old 01-19-2008, 10:10 PM   #4
virtual PC is bad emulation compare to to Parallel. way to slow to run and I never had good results with anything.
I would say you need to use PC ....
I make a living working on PC or Mac so I know well
Old 01-19-2008, 10:13 PM   #5
i know virtualPC is horrid, but it's all i have - and my mac works beautifully on everything else (been using macs for almost 20 years now). all i use VPC for is castle link, lol.
Old 01-19-2008, 10:19 PM   #6
too bad for you..I think you are out of luck on this...even parallel don't work well on some USB products so you are in dark ages...
Old 01-19-2008, 11:51 PM   #7
Hey us mac users are supposed to stick together.
Old 01-20-2008, 09:31 AM   #8
that's what i thought too...! :-(
Old 01-20-2008, 02:15 PM   #9
Keep your eyes open for a cheap Intel Mini. You can use it as a media player hooked to your TV, too.
BTW: I'm a Mac dealer, and you're right: we need to stick together!
Hodaka is offline   Reply With Quote
Old 01-20-2008, 06:35 PM   #10
I'm using Parallels to to run XP also. I can use the USB for my Mamba Max but not for the Castle Link hooked up to my new CC BEC. Anyone having this problem????
The Gooch
El Gooch is offline   Reply With Quote
Old 02-01-2008, 02:43 PM   #11
Gooch...if your CC BEC is already connected to an ESC it may be drawing too much current away from the CC BEC. Try plugging the CC BEC into the link, then plug your battery pack into the BEC/ESC connection. Should power up fine. Make sure you have at least Castle Link v3.01 software on your computer as well. Let me know if you're still having issues.
Joe Ford is offline   Reply With Quote
Old 02-01-2008, 04:30 PM   #12
Where are you guys getting xp? I can't find a cheap source.
Calderwood is offline   Reply With Quote
Old 02-01-2008, 05:44 PM   #13
I got mine at the UCSD book store through a friend. If you or a friend is going to a state school, you can get through the book store.
Old 02-01-2008, 05:45 PM   #14
Than you for the help. I'll try it later tonight when I get home.
Old 02-12-2008, 11:49 AM   #15
I'm still having problems. Do I need to have a battery source hooked up when I'm using the castle link? Because when I hook up the Mamba Max it works fine without any battery source. To the computer that is..
The Gooch
Old 02-12-2008, 12:57 PM   #16
Gooch...plug the CC BEC into the little green board on the Castle Link, then plug the battery pack into the ESC/CC BEC connection. Do it in that order. If you plug the battery pack into the ESC/BEC connection, then plug into the link it will not work.
Old 02-12-2008, 01:02 PM   #17
So the last step would be to plug in the USB to the computer,or the battery to the BEC?
Old 02-12-2008, 02:10 PM   #18
Hmmm...
Mine worked fine when I did it this way:
Plug Link into computer and start Software.
When software has initialized and sees Link, plug BEC into Link - I did not have a power source connected to the BEC at all.
iMac 2Ghz Core Duo, 2GB RAM, XP running under latest version of Parallels.
Old 02-12-2008, 02:48 PM   #19
Originally Posted by Hodaka View Post
Hmmm...
OK, I'll try it again, like I said earlier, the Mamba Max works fine.But when I need to use the software, it just doesn't see the castle link?
Thank you for your help, I'll let you know how it works.
Old 02-12-2008, 06:05 PM   #20
Still no luck, the software still doesn't see the castle link.
