11-14-2008, 03:54 PM | #21 |
It can operate without the cap, but the FETS are at risk of premature death. I forgot to put mine on and ran it that way for months, and on a high power setup too. NOt a good idea.
11-14-2008, 07:54 PM | #22 | |
I wanna be Dave Join Date: Jun 2004 Location: Whales
Just a thought | |
11-14-2008, 08:04 PM | #23 |
RCC Addict Join Date: Nov 2005 Location: Utah
I agree with what brett said ^ I actually laughed when i saw that post I love my FXR and actually like the fact that it is on the out side of the box. I dont think the word "poor design" should be associated anywhere near the word tekin or FXR, IMO they created the best esc for a crawler. |
11-15-2008, 01:32 PM | #24 |
I would also prefer the HUGE cap inside of my FXR case, instead of outside the box. Tekin could make the case slightly taller and fit it inside and it would be easier to see the LEDs when programming and to get my finger in there to push the buttons.
11-15-2008, 01:57 PM | #25 |
Pullman Crawler Join Date: Jul 2007 Location: Pullman
i love mine! and on putting that thing inside. i like it just as it is. you can solder a wire to each lead and to the esc then you can mount it anywhere. keep it out of the way of just mount it in a dead place that nothing else could fit in and keep the CG lower. to Tekin and the FX-R. oh also if there is anyone in the California central valley that want to stop by and use my hot wire PM me. Last edited by A_Jeeper; 11-15-2008 at 02:00 PM. |
11-15-2008, 05:22 PM | #26 |
Newbie Join Date: Aug 2008 Location: Lower Mainland, B.C.
11-19-2008, 12:04 AM | #27 |
Quarry Creeper Join Date: Jul 2008 Location: Newark
I just got my fxr...and I'm using the cap, I'm running it with 2 35T motors and my esc is getting hot...is anyone else experiencing thi kind of problem?
11-19-2008, 12:14 AM | #28 |
Pebble Pounder Join Date: Sep 2008 Location: Thornton
What size battery are you using?
11-19-2008, 08:50 AM | #29 |
| I'm using a 3S 2000mah lipo battery...I was thinking if its because I'm running 2 motors on a berg axle geared @ 14T front/13T rear....IDK maybe I'm over analyzing it...so, I was planning on getting another FXR, one for each motor...need help! might just get a fan and face it to the solder poles...its lighting up all 6 LED with just 5 minuts of running.
11-19-2008, 09:21 AM | #30 |
Are you running the caps?
11-19-2008, 09:55 AM | #31 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
You probably should have gone with the FXRpro, we rated the FXR to 3S with one 35T motor, having two is pretty good load for it to handle.
11-19-2008, 02:42 PM | #32 |
This makes me curious, John, how many turns are your mini torquemaster motors? What do you guys think about running a 3s lipo with a MTM on my fxr? It has run fine so far, I guess I never considered the turn count, I just figured the load with the small motor would be safe...
11-19-2008, 05:35 PM | #33 |
Pebble Pounder Join Date: Jul 2008 Location: Trumbull, CT
just an fyi you dont need to put it on the esc you could put it near the battery http://www.batteryspace.com/index.as...ROD&ProdID=600 |
11-20-2008, 10:02 AM | #34 | |
If you have it out there on 6" of wire plus it's on the other side of a connector, that's a lot of resistance that the ripple current would pretty much disappear in and never make it to the cap, then the cap would have nothing to give back to the ESC when it switches and makes a connection again. | |
11-20-2008, 10:05 AM | #35 |
Right, the cap is there to smooth out the ripple voltage caused by fet switching. It needs to be as close to the FETs as possible to work properly, IE where tekin recommends in the instructions. Installing it anywhere else will ruin the fets in a hurry.
11-20-2008, 10:53 AM | #36 | ||
11-20-2008, 11:03 AM | #37 |
Yes, the pro will do that.
11-20-2008, 12:06 PM | #38 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
So you guys are saying for those folks running Berg and 35t or 45t motors that the FXR is not recommended or will fry and we should buy a 2nd or a FXR pro also if it's so important that the cap be close to the poles why didn't Tekin put the cap inside I have had many Tekin ESC's and very happy with them, they usually last longer than my novaks. Cap outside makes NO sense other than you can replace it or upgrade it...? My ESC's Tekin FXR just bought for berg still in box Tekin TSC 411 G2 from a 107mph drag rc 18 cell yr1988 Tekin TSC 610-R from 1995 stop working in 2006 Tekin Rebel2 x2 2006 Castle Mamba max 2007 Novak T-1X 1988 Novak 610r 1996 Novak 610 hrv x2 1996 novak fried T4 Last edited by toy4crawlin; 11-20-2008 at 12:15 PM. |
11-20-2008, 01:01 PM | #39 | |
Basically, we're saving you money and making it easier to keep your ESC operation. So quit whining! :-P Ty | |
11-20-2008, 01:06 PM | #40 | |
I guess with the new high power of these amazing ESC's that is a great idea for replacement. again my apologies | |
