Thread: If you were to buy one ESC and One Motor ?
Old 05-16-2009, 08:34 AM   #1
Default If you were to buy one ESC and One Motor ?
If you were to buy one ESC and one motor what would it be ? I am working on a wheely King right now but would like to upgrade when I get more $ . So, I will be transferring the ESC and motor into the Losi 1/10 when it comes out.
I would like to have a bulletproof esc and motor that can be used competatively in comps also.
Thanks,
Raz
RazBarlow is offline   Reply With Quote
Old 05-16-2009, 08:56 AM   #2
Default ?
What are you planing to do with it? Crawler,Mudder,Scaler,Racer,Basher.
Need more info to make a sugestion.
lucky13offroad is offline   Reply With Quote
Old 05-16-2009, 09:00 AM   #3
Mamba max and a holmes cobalt puller. Hands down the best combo on the market
chrisjlittle is offline   Reply With Quote
Old 05-16-2009, 09:06 AM   #4
I want to crawl/scale and when get practiced up I want to compete with the Texas boys !
Old 05-16-2009, 09:19 AM   #5
I just bought a castle creations sidewinder with link and bec. So far I'm just lovin it. I think the drag brake is a tad week, but it still does its job. I'm pushing a 55T Integy motor. I'm liking it, but I think it needs more top end. Might bump it up to a 45T. If money is tight like my budget, this has been a great setup. Comp worthy, I'd say so, but I'm just an FNG around here :-P
PDXFNG is offline   Reply With Quote
Old 05-16-2009, 10:47 AM   #6
That Integy motor is what makes your drag brake week, swap it for a good handwound Holmes motor and you'll see a difrence.
I run a MM/Cobalt 10t and a Sidewinder/35tHHH, I highly recomend either one of these setups.
LIKES2CRAWL is offline   Reply With Quote
Old 05-16-2009, 10:56 AM   #7
If you can wait JRH is coming out with a wicked ESC, purpose built for crawlers, that should be out in July. You can check it out at his web site. Pair that up with one of his handwound 35's or a puller, and you should be pretty well pleased. Just my 5g of copper plated zinc...
ohmyCLOD! is offline   Reply With Quote
Old 05-17-2009, 05:23 AM   #8
Tekin FXR Pro and Cobalt Puller
Culetto is offline   Reply With Quote
Old 05-17-2009, 07:02 AM   #9
Tekin FXR and a Tekin 35 T
JEracing is offline   Reply With Quote
Old 05-17-2009, 07:06 AM   #10
I am kinda new to the crawler scene , but this setup would work for practice and comps also ?
Being ignorant , why the 35 T over the 45 or 55 ?
Thanks,
Raz
Old 05-17-2009, 07:37 AM   #11
FXR and 55T Integy motor, here
IMO you can't go wrong with the FXR, i love it
I might have to look into this more, i guess when you pay $22
prusik333 is offline   Reply With Quote
Old 05-17-2009, 08:06 AM   #12
TEAM MODERATOR
Reflection's Avatar
Mamba Max and a 10t Holmes Cobalt puller....it really is all that and a bag of chips. If I couldn't run that,it'd be a Mamba Max and a 35t Holmes Handwound. Other ESC's do a really good job. It's hard to beat the robust features of the max though. It's really hard to hurt one in a crawler.
Reflection is offline   Reply With Quote
Old 05-17-2009, 12:38 PM   #13
X2
oldhippie is offline   Reply With Quote
Old 05-17-2009, 02:03 PM   #14
X2!!!! And a castle BEC wouldn't hurt either.
mudrinner4ever is offline   Reply With Quote
Old 05-17-2009, 02:33 PM   #15
Thanks,
Raz
It is about the wheel speed, needed to pop up over the hard spots.
bcbaja is offline   Reply With Quote
Old 05-18-2009, 09:25 AM   #16
Big Mike's Avatar
X2 - the widest range of adjustability of any esc, and best combo of torque and wheelspeed of any motor.
Tekin FX-R's are also very capable, and in a much smaller footprint if space is a factor in your build plans. I'm running my 7t CP on one now, it's very smooth and the drag brake is solid as a rock.
The FX-R also has "push control" which I'm really liking for my scale truck, it lets the truck coast for a bit when you let off the throttle instead of instantly locking up the wheels. It makes the operation of the truck look a lot more realistic. If I need to stop fast or on an incline, slightly pushing past neutral into reverse locks the wheels. Going back into neutral then into reverse again engages reverse.
Or for comp use you can set instant reverse w/ no brake or push, just drag brake...
Big Mike is offline   Reply With Quote
Old 05-18-2009, 09:47 AM   #17
I'm building a new rig with a Holmes Cobalt 10T motor. Can you explain what the advantages of running the Mamba Max over a Sidewinder would be for this motor? I haven't bought an ESC yet.
SgtDoogie is offline   Reply With Quote
Old 05-18-2009, 01:54 PM   #18
Default it gets the job done....
budget wise...i use a rooster and a 55t novak combo. if you buy cheap you get cheap???i know mine is not super expensive, but it works better than stock.
bigjay1973 is offline   Reply With Quote
Old 05-18-2009, 06:36 PM   #19
FXR and an integy 35t. Cheap motors are the best, that way when/if they quit, you arent as mad lol
axman2010 is offline   Reply With Quote
Old 05-19-2009, 10:19 AM   #20
Originally Posted by oldhippie View Post
X2
I've got a fxr pro I'm pulling of my comp crawler that is good to go--has maybe 10 packs through it. I loved it. Its small and very easy to use. It has wires, deans, and a CC BEC all soldered in. I take $120 plus shipping for it.
Let me know.
Chris
792.5cj5 is offline   Reply With Quote
