08-09-2009, 02:27 AM | #41 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
08-09-2009, 07:47 AM | #42 | |
Rock Crawler Join Date: Sep 2008 Location: Portland
Your right they haven't but the one before the 9100t was the 9000t, same servo just without red heatsink, that was around for a long time. And the 8711 was something else to a few years ago. | |
08-09-2009, 08:40 AM | #43 |
Rock Crawler Join Date: May 2007 Location: Norwich
hobbico CS-170 great servo for the money. I'm pretty sure it is a rebadged Hitec. I've run them in all three classes without a problem.
08-09-2009, 09:46 AM | #44 |
Quarry Creeper Join Date: Jul 2007 Location: Fort Mill, SC
I bought my RTR 'comp' rig used, it had Cirrus hi torque servos in it. The dig servo lasted 2 battery packs. the steering servo lasted a while, but ran hot as hell, even just fooling around in the house. Autopsies showed that they had both burned out their circuit boards. I've been using Futaba stuff for 20 years, it always done well for me. Therefore the Futaba S9156 was a no-brainer for me. I chose the 9156 over the 9157, because I knew the 9156 was going to give me all the torque I needed. The 9157 would too, but with a higher power draw. I didn't want that. I have run it on hot days, in some serious terrain, for a long time, and it barely gets warm. In my book, you get what you pay for. |
08-09-2009, 09:47 AM | #45 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
For the shuttering, is it just a little bit, like one or two degree's? If so, take it apart and spin the gear set around so your using the other side of the gears. It's just trying to center itself and it doesn't think it can because there is slop.
08-09-2009, 01:27 PM | #46 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
Running a 9100T for steering and 645mg for dig. Bought the 9100T to try as steering in my 1/8 buggy, didn't like it, so in the crawler it went. Been running it for about a year, running old novak super rooster, no external BEC. Also have 7955TG for steering in my buggy, I love its speed and torque, I am hoping to try the new 7950 with unrestricted lipo someday, and I will probably end up transfering the 7955 to the crawler. I have managed to burn up a servo in my 1/8 buggy, a 925mg for throttle, caused a runaway that killed my OS V-spec RB mods. I don't think I have broken any other servos actually. |
08-09-2009, 01:37 PM | #47 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
Futaba S3305 HT MG Servo. They are cheap $30.00 and work great! I use them in all my RC's and have had only one fail and that servo was a year old. The other 4 are still going strong.
08-09-2009, 07:50 PM | #48 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
| all hobbico servos are rebadged hitecs. The cases are all molded with the hitec servo# under the hobbico sticker. Years ago when I mangaged a LHS I had one of the great planes dealer reps tell me they were seconds from the factory that manufactures Hitec servos, but ive never found any flaws with them. Id say they are just a tad out of hitec's "specs" electrically. As for myself, Im a futaba and KO propo guy (although at the moment Im running a hitec 5955 in my comp truck because i couldnt pass up the deal..) Ive tried using JR digitals since they first released them and Ive had a ton of trouble with them. Scottmisfits is right about the shuttering. Its because the servo doesnt think its centered correctly and keeps trying to correct it over and over, which causes overheating. Its the only thing I hate about digital servos. Try flipping the gears and if that doesnt work, check out the bushings/bearing/shafts that the gears ride on. One of them is probably worn or bent. Futaba and KO servos may be more expensive, but ive never had a high end futaba or KO digital servo go out. Has anyone tried any of the Orion digital servos yet?
08-09-2009, 09:59 PM | #49 | |
08-10-2009, 06:09 AM | #50 |
08-10-2009, 06:21 AM | #51 |
Newbie Join Date: Jul 2009 Location: Sweden
I'm running Savöx 20kg servos, which I think are the same as Orion. Working great so far, digital and with all titanium gears.
08-10-2009, 12:43 PM | #52 |
Rock Crawler Join Date: Apr 2009 Location: Pa
I'm running a Hitec 645MG/TP 995MG "Hybrid" servo right now in my scaler. I burned up the motor in my 645 and had a brand new 995 laying around. Tower Pros electronics suck but the motrs are the same chinesse quality as the Hitec. I replaced the 645 motor with the 995 motor. Now I got a servo with all the accuracy of the Hitec but with quite a bit more torque than a standard 645 thanks to the donor motor.
08-10-2009, 12:48 PM | #53 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
i run a 9100t simply because i have not yet managed to break it LOL time will tell. |
08-10-2009, 04:08 PM | #54 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
Im glad to see im not the only one that is having trouble with the JR stuff... |
08-15-2009, 10:16 PM | #55 |
08-15-2009, 10:33 PM | #56 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
I run JR8711's in almost all of my crawlers and the ones I don't I run HiTec 5955's I've never had either fail on me and they have POWER, POWER, and more POWER JR has a killer warranty's on there stuff to! HiTec stands behind there's as well. But I say this on what friends have said about the warranty's, I've never had to send one in!
08-15-2009, 11:34 PM | #57 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
Maybe if you drove better Mike you wouldn't be ruining perfectly good servos. But seriously, I have had my DS8711 bound up and never had an issue. This thread is making me nervous because now it will probably fry! Has this problem occurred more with the 9100's or equally for either? |
08-16-2009, 12:30 AM | #58 |
Rock Crawler Join Date: Jun 2009 Location: SF
| orion servos are rebranded KO servos that accept futaba horns. Is this a rebrand rebrand?? Orions are great, run them in my offroad racers...b4, b44
08-16-2009, 12:35 AM | #59 |
Oh yeah, JR DS 8711 for me w/cc bec, no issues yet...flawless.
08-17-2009, 12:05 AM | #60 | |
Rock Stacker Join Date: Dec 2008 Location: c-wood
i run the 925mg for a dig servo(got it out of my kyosha(sp) nitro buggy) and a 645mg for steering both work awsome at 6volts (ccbec) although the 925 is alitte fast for my likein on the dig it kinda just rams it home instead of easeing it in | |
