11-28-2010, 01:19 PM | #21 |
Rock Crawler Join Date: Mar 2009 Location: AZ
Ya I will be running my dual fxr's on my super and as of right now I am sitting right around 10lbs. I was also planning on putting the same setup on the 2.2 xr which is sitting at around 5lbs 11oz. But I'm sure the super will put it to the test. Going to be wiring it up today.
11-28-2010, 01:24 PM | #22 | |
Pebble Pounder Join Date: Oct 2004 Location: San Diego
What motors are you running in each? Mine is goin into my xr10 as well (dual fxr)... I dont have the batt pack, yet.. just ordered one to test out. (same physical size as my 3s 1300mah pack.. and it fits very nice in the V4 Juice chassis). ( http://www.cheapbatterypacks.com/?ap...474&bc_menuid= ) wife is picking up the capacitors for me as we speak (christmass shopping next to radio shack)... Last edited by MOTORRAD; 11-28-2010 at 01:26 PM. | |
11-28-2010, 01:27 PM | #23 |
The super has two 45T brood motors and the xr has two 45T banzai motors at the time being although I will be switching over to the broods in the xr.
11-28-2010, 10:46 PM | #24 | |
If anyone is willing to open up the case on their FXR.. and take HI REZ pics of the parts in there.... so I can read the part numbers... I have a elec engeneer buddy, that builds his own esc's etc. that can tell us if she can handle it... I just dont want to crack open my 2 week old ones and kill all warrenty | |
11-29-2010, 12:29 AM | #25 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
I was told a while back by the electronics man on here JRH that technically if you change the caps they should handle it, tekin just said we've never tried it. I haven't tried it myself and I don't intend to at this stage, 3s is enough for me at the moment. Kieren |
11-29-2010, 12:41 AM | #26 |
Rock Stacker Join Date: May 2007 Location: Fort Payne
The Most important thing is :: as voltage goes UP amperage goes DOWN. resistance inside the circuitry stays the same. Resistance Is basically the abliity to Dissapate HEAT! Restance times Amperage equals wattage.. How many watts a motor can utilize depends on the turns or manufacture specs. long to short if you run a 80 turn on 4S probably if you run a 19 turn probably not if you run a 3s and 8 turns smoke I have ran 6s on a 10.5T brushless in a LCC gear Down to prevent binding and stalling and watch the temps close for the first few runs. pick a good line and jumpit. |
11-29-2010, 09:11 AM | #27 | |
To say that resistance dissipate heat is laughable, it's what creates it. Resistance x amperage does not equal wattage, it equals voltage. Voltage x amperage equals watts. | |
11-30-2010, 12:18 AM | #28 | |
RCC Addict Join Date: Jan 2005 Location: Germany north
nippon chem con ps series ESR 14 mOhm max/20°C, 100k to 300kHz rated ripple current 5,050 mArms/105°C, 100kHz) makes no sence to buy more capacity with higher ESR and less ripple current | |
12-06-2010, 02:58 PM | #29 |
Any updates Diamond????
12-29-2010, 12:24 PM | #30 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
So if you are going to use the 1000uf caps that nova sells, would you need to install two of them, one for each esc like stock, or just one?
12-29-2010, 01:43 PM | #31 |
12-29-2010, 05:48 PM | #32 |
02-18-2011, 03:50 PM | #33 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
02-18-2011, 07:04 PM | #34 |
Newbie Join Date: Feb 2010 Location: Calgary, Ab
I have dual FX-R's and have only ran 4s 1250mah lipos. I have 35T motors and no smoke yet. BJ V2 Berg. |
02-18-2011, 07:20 PM | #35 |
Quarry Creeper Join Date: Sep 2010 Location: Central MN H-Town
if you're going to change out the capacitors then I would avoid the radio shack caps. I have not had an issue personally with them but most there are rated to 85 deg whereas for not much more money you can get a more stout cap from somewhere else. I have always used caps from mcm electronics and had no issues yet and they have them rated to 105 deg. |
02-18-2011, 07:36 PM | #36 |
06-21-2011, 09:49 AM | #37 |
Newbie Join Date: Apr 2011 Location: NW AL
I have run my fxr pro on 4s lipo a little. I changed the cap out for the 35v 1000uf radio shack one and used hotwire to set a 4s lipo cutoff for the esc. Ran a pack (1600mah, 40c, 4s) through yesterday with 2 30t motors (on an xr10) with no problems. I did try it with a pair of 17t reedy radon motors. No damage to the esc but the motors only lasted about 45 sec before the rear one caught fire, came apart internally and locked up. Wheelspeed was wicked though! Any thoughts on the fastest motor I could run that would stay together? (for occasional FOFF side trips) A side note: my 30t motors seem slower than the 35t's I'd been using. 35t's were cheapo HPI saturn and the 30t's are better HPI x30's. They are slower on 3s and only about as fast on 4s as the saturns are on 3s. I switched it back to the saturns on 3s for now. I like these motors fine, just wish they had a touch more drag brake. I may try some HH handwound 33t later on. |
06-21-2011, 11:14 PM | #38 |
Pebble Pounder Join Date: Apr 2010 Location: Mt Albert
Well,I'm worry about my dual fxr's running with HH 45t motor will cook it or not? |
06-22-2011, 07:19 AM | #39 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
I run 4s on my RS esc's with larger caps Eddie sells and it worked fine... the FXR's however seem to run ALOT hotter so im not sure if its worth 4s...
06-22-2011, 11:37 AM | #40 |
| I'm sure it will shorten the life of your motors, but it won't instantly fry them and it won't hurt your fxr's at all as long as you install the right cap and use an external BEC.
