06-22-2011, 11:48 AM | #41 |
Rock Crawler Join Date: Dec 2008 Location: dallas
I have ran my fxr's on 4s for quite some time(with some coating even fully submerged wot) with no issues. Get hgher volt caps and roll. I run 16 turn 5slots or 35 turns
06-22-2011, 09:59 PM | #42 |
Pebble Pounder Join Date: Apr 2010 Location: Mt Albert
| Thanks dude..So what I shall'd do just need cc bec connect with battery and other end directly into RX? |
06-23-2011, 08:43 AM | #43 |
Newbie Join Date: Apr 2011 Location: NW AL
12-31-2011, 10:02 AM | #44 |
Rock Crawler Join Date: Sep 2011 Location: truckee
| Re: Tekin FXR and 4 cell Lipo
so to the people running 4s on the fxr, what did you set the voltage cutoff to? it should be around 13.2 right? with the hotwire i can only get the setting to go to 12. what am i missing? thanks!! |
07-09-2012, 02:17 PM | #45 |
Pebble Pounder Join Date: Apr 2012 Location: SWE
And then!! pick it up, its itching everywere 4s sounds great Last edited by nitrooxide; 07-09-2012 at 02:20 PM. |
07-10-2012, 02:46 PM | #46 |
bump again. come on ppl , you guys were did you all go? So how did it go etc etc. how many 4s packs are you up to atm?? please let us know. |
07-10-2012, 08:15 PM | #47 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
i ran dozens of packs before i gave up on 4s eating berg 3rd gears. but the fxrs held up without issue.
08-08-2012, 02:19 PM | #48 | |
| Re: Tekin FXR and 4 cell Lipo Quote:
My Wraith is a blast on 3s 40C with Traxxas Titan 21T 550 motor, and 13/56 32 pitch gearing!!! I'm getting the itch to drop to 12/56 gearing and up to 4s 40C...not sure my driveshafts and gears will like it though. EDIT" Yes I'm running external CC BEC. | |
08-08-2012, 02:29 PM | #49 |
| Re: Tekin FXR and 4 cell Lipo Your titan motor is not going to like 4s. It will take it, but it will not last long. The brushes are not serviceable, and they will not last. But it will be fun while it does, and at $23 a pop, the motors are cheap enough.
08-08-2012, 02:36 PM | #50 |
LOL, I was afraid of that but I'm really loving the torque and wheelspeed lol....makes me giggle uncontrollably... Yes, I knew about the brushes but they are harder compound than most serviceable types...any idea how long it would last? What motor would you recommend that will last and have powder like the Titan 21T?
08-08-2012, 02:59 PM | #51 |
I would stick with the titan motor, just expect to replace it. How long it lasts really depends on the luck of the draw. Brood makes 550 motor and it is priced well, but I have not ran one, or even seen one run so I cannot speak to that motor itself ( no specs on the page, maybe EddieO will chime in). I can only speak to the incredible performance of Broods other products and, IMO, if he is willing to put his name on it, it must be a decent product.
08-08-2012, 04:56 PM | #52 | |
08-08-2012, 06:12 PM | #53 |
It's not the brushes on the Titan motors that are the problem in my experience with four of those motors. It's the brush springs bending and failing. They're bent tabs, and they get too bent and warped or snap apart and don't work anymore. And that was on 3S lipo.
08-10-2012, 04:02 PM | #54 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Does anyone know if CI still sells the larger caps, I could'nt find them on his site. I've got dual FXR Pro's and some 1250mah 4s lipo's for my super and need the bigger caps. TIA.
08-10-2012, 04:29 PM | #55 | |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
TT3518 16V 180uF B1 B1R Series (2) TT3520 16V 330uF Fx R1 series (2) TT3522 16v 1000uF all units (2) TT3543 25V 1800uF 5S lipo (2) TT3544 25v 2200uF 5S lipo (2) TT3545 25V 2700uF 5S lipo (2) TT3552 35V 1500uF 6S lipo (2) Last edited by PaloAltoK5; 08-10-2012 at 04:32 PM. | |
08-10-2012, 04:29 PM | #56 |
| Re: Tekin FXR and 4 cell Lipo Thanks, they probably overheated the springy tabs that the brushes are attached to and lost their tension, then it arced more, got hotter and melted down? |
08-10-2012, 04:32 PM | #57 | ||
4S Heavy Duty Tekin FXR Capacitor Quote:
08-10-2012, 05:05 PM | #58 | ||
Thanks guys , I noticed the Tekin 1000uf cap is still 16 volt where as the one from CI is 25 volt. The 4s are 14.8 volt, pretty close, maybe the 1800 uf would be a better choice at 25 volts. Quote:
Quote: | ||
08-10-2012, 05:09 PM | #59 |
| Re: Tekin FXR and 4 cell Lipo Yes, better to have a little more capacitor than you need. When they get overheated they burn up and or pop. Just replaced a motherboard in computer last week with several burnt and puffed caps lol.
08-10-2012, 05:59 PM | #60 |
| Re: Tekin FXR and 4 cell Lipo |
