01-08-2012, 09:49 PM | #1301 |
| Re: Cutting a motor commutator & motor tweaks
cool deal, I can't wait for mine , I am already looking for arms and springs to start building my stuff |
01-08-2012, 10:53 PM | #1302 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
It's a lot of fun. I'm on my third armature right now. I'm hooked!
01-09-2012, 12:04 AM | #1303 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
| Re: Cutting a motor commutator & motor tweaks |
01-09-2012, 06:45 PM | #1304 |
I was goofing around this weekend and rebuilt (as best as possible anyway) a fried 15t hpi firebolt sealed can motor. Rewound it and cut the comm on the lathe. Not much to do for the brushes other than scuff 'em up and reuse them. Anywho, I decided to try the "chuck it up in a drill and see the kv" thing. I did the math and it came out to approximately 3500kv. That didn't sound right at all, so I tried another, much better quality 27t motor and it came out to 4375kv. The drill spins @ 1400 rpm, the 27t motor put out .32v. 1400 (rpms) x 3.125 (1/.32) = 4375 rpm's per volt, right? |
01-09-2012, 08:38 PM | #1305 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Yer formula is correct... Keep in mind, many 27t motors are pure RPM machines....they would cut the crap out of the arm until there was nothing left. It was not uncommon to see racing stock motors make more RPM than a 19t race motor, which was required by the rules to use a full stack armature. Later EddieO |
01-09-2012, 09:14 PM | #1306 | |
| Re: Cutting a motor commutator & motor tweaks Quote:
That 27t is one I wound on a Reedy 15t arm and it looked fairly normal, but I know what you're talking about. I've taken some 27t's apart and there wasn't much meat there. | |
01-09-2012, 11:53 PM | #1307 |
Epic Binary stock comes to mind with high rpm stock motors. Checked the kv on one a while ago and it was 4880. Thing has pretty much no steel in the arm at all. |
01-11-2012, 05:24 AM | #1308 |
.....and "stock" race motors have 24 degrees timing and laydown brushes. Both affect Kv. Try checking the stock motor in both directions and see the difference.
01-11-2012, 06:15 AM | #1309 | |
Nobody Join Date: Sep 2008 Location: Maine
01-13-2012, 08:46 AM | #1310 | |
Rock Crawler Join Date: Apr 2009 Location: Pa
Keep an eye on the ways for knicks. (I see there is already one on yours) When I first got mine there was a knick on the one way which caused the lathe to turn a taper. I stoned the knick out and it took the taper out. Why isn't this thread a sticky yet. | |
01-13-2012, 08:51 AM | #1311 |
01-13-2012, 09:45 AM | #1312 |
I was playing around with some graphs to show a better visual. Here is a comparison of the Tekin Pro pre rebuild vs post rebuild/tune. Note that it's not apples to apples as the pre rebuild is the motor at 0 degrees timing in excellent condition, likely what it would be as provided from Tekin. The post is at a crawler friendly 6 degrees timing advance. I think it shows how an off the shelf motor could be better with some tuning and small timing advance. Here is a comparison of the post rebuild/tune Tekin vs. the HHK in the P-94 can Last edited by Cordwood; 01-13-2012 at 03:13 PM. |
01-13-2012, 12:17 PM | #1313 | |
Hey dkf A nick on what? Can you please explain for me? The comms I have turned have exact OD at both ends. BTW, that was my first com cut. I'm getting better with each one. Thanks for the input Quote:
01-13-2012, 12:26 PM | #1314 | |
When I got my lathe as I said it was cutting a taper. My knicked way was on the longitudinal feed though which caused the taper. I was running over the raised metal from the knick which caused the taper. I stoned down the raised portion and the taper went away. The aluminum on these lathes is heat treated but it is still fairly soft. I was just giving you a heads up so you can avoid issues. | |
01-13-2012, 01:34 PM | #1315 |
01-13-2012, 02:57 PM | #1316 |
Nice graphs yo!
01-13-2012, 04:59 PM | #1317 |
01-13-2012, 05:54 PM | #1318 | |
Thanks for the heads up dkf Quote:
01-15-2012, 06:52 PM | #1319 |
I was rebuilding my motors (Brood 35T HHKs) to get ready for ACC and I had one of my best cuts yet....so I thought I'd post a pic: (I know, the camera is shitty and has a hard time focusing on the comm) |
01-15-2012, 07:30 PM | #1320 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/223989-cutting-motor-commutator-motor-tweaks.html | ||||
Hiilimoottorin kunnostaminen | This thread | Refback | 10-04-2011 03:19 PM |
