02-17-2012, 11:33 PM | #1601 | |
| Re: Cutting a motor commutator & motor tweaks Quote:
EDIT: Actually, homes hold on the BRXL is about the same with brushed 540's. | |
02-18-2012, 09:14 AM | #1602 | |||
Killer deal!! I wonder how many of us are scouring ebay for old parts? I picked up a nice old motor lot for $50, and it came with a Hudy lathe! | |||
02-18-2012, 09:42 AM | #1603 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
| Re: Cutting a motor commutator & motor tweaks |
02-18-2012, 10:06 AM | #1604 | |
Nobody Join Date: Sep 2008 Location: Maine
No kidding. I got outbid last minute the other night on something and I thought to myself, "I wonder which one of those f'ers in the comm thread outbid me!!" | |
02-18-2012, 10:10 AM | #1605 |
Pebble Pounder Join Date: Sep 2010 Location: Lees Summit
02-18-2012, 10:26 AM | #1606 |
I won't tell yall how much I paid for the motor lot plus Motor master then, lol! I did proceed to kill the motor master within about 10 motors though. Had a lead slip off a motor and it shorted the FET inside. Back then they didn't have current limiting built into those sorts of things. I'll post up when I get around to tearing the thing apart and replacing the FET. I have a bunch of the same TO-220 legged fets here from building ebike controllers to my specs. |
02-18-2012, 10:48 AM | #1607 | |
02-18-2012, 10:48 AM | #1608 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Hudy Lathes can be tougher to find good deals on, because they can easily be converted to a slot car lathe....slot car guys will be using brushed motors till the end of time.......so the lathes are not as easy to find cheap. The orion, reedy, trinity, etc are ALL capable lathes. Don't get caught up on having to use a Hudy......I only use mine to cut mini motors. If anything you should be caught up getting a fantom....there is a reason I have 6+ of them. I've been saying all along there is TONS of good stuff out there. RC racers don't throw stuff away, just gets put in the closet.......they will give it away for nothing to another hobbyist before throwing it away. It's much cheaper to buy a set of arms and get them rebuilt than a whole set of motors.........4xfords deal is a great example......basically $15 for a pair of motors, $60 for some armatures.......$75 bucks and done! Round brushes with heavy springs would probably have the ability to handle more voltage the best. Your big issues with voltage is brush bounce, along withDetonationof the comm. Round brushes counter act this the detonation, while stiff springs help the brush bounce....if I was to pick, I would say the v2 brushes do a better job of it than anything out there. I might get bored to day after orders are done(yeah, EddieO works on saturday too).......post up a pic of tool, see if anyone can guess what it is......maybe a prize to the winner? Later EddieO |
02-18-2012, 11:49 AM | #1609 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
As Eddie said the fantom is the one to chase, it's very sturdy you could droop it and still cut a perfect comm, others you would need to check its true still
02-18-2012, 12:02 PM | #1610 |
02-18-2012, 12:08 PM | #1611 |
Any idea what is? What it was for? How much it cost? There was only ever three of these made...... Some brood fluids to first person to get first two questions right Later EddieO |
02-18-2012, 12:14 PM | #1612 |
Stack and comm jig!!!!!! used to align comms
02-18-2012, 12:19 PM | #1613 |
Right on A....not for B....well I guess sorta could be used in that. Later EddieO |
02-18-2012, 12:20 PM | #1614 |
Change the alignment, to cheat in stock class
02-18-2012, 12:22 PM | #1615 |
02-18-2012, 12:37 PM | #1616 |
I'm stumped if it didn't check or change the alignment. It's probably some of the internal parts to your jigatron-2000 penis pump... |
02-18-2012, 12:49 PM | #1617 |
Well there ya go, you answered it without even realizing it... It was used to check the comm timing. We never used it to adjust it really though, as it was too delicate and expensive for something like that. Stock motors often had comm timing all over the map, so when you buy 3 handouts.........times 10 racers, it was much easier to figure out which arms would be better than the other using simple tests (those sometimes arms defied logic). Only 3 were ever made, one for his son, a national champ......he made one for me and one for Scott Ernst, who runs a lot of races as a tech tool.....they were EDM cut.....cost, $400. Later EddieO |
02-18-2012, 02:00 PM | #1618 |
Looks like a handy little tool.
02-18-2012, 02:12 PM | #1619 |
It was very handy back in the day..... I use it now during the matching process....getting stuff as identical as possible prior to building them makes the motors pretty much in sync once they are built... Later EddieO |
02-18-2012, 03:56 PM | #1620 | |
Cool little tool! I bet it really helps spot the differences between arms. Cut for 7.5mm arms? | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/223989-cutting-motor-commutator-motor-tweaks.html | ||||
Hiilimoottorin kunnostaminen | This thread | Refback | 10-04-2011 03:19 PM |
