03-10-2012, 09:47 AM | #1701 | ||||
| Re: Cutting a motor commutator & motor tweaks Quote:
03-10-2012, 12:03 PM | #1702 | |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Seems odd since many of your top team guys have build threads with detailed information on changes they make to the rigs. I guess ideal is in the mind of the beholder... After 36 years of listening to "it rains a lot there" it gets old, so many learn the stats. My photo got picked apart...I simply asked what the stuff was on yours.... But to comment on the rest arm...winding looks good, solder job looks solid...epoxy looks applied uniformly...comm cut looks spiffy Later EddieO Quote:
03-10-2012, 12:07 PM | #1703 |
| Re: Cutting a motor commutator & motor tweaks I don't think he did that...I was wondering about that stuff too, but didn't care enough to ask because I was relatively sure that it all gets cleaned up in the build process. A lot of things can look a bit funky early on in the manufacturing...
03-10-2012, 06:20 PM | #1704 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
More Ebay findings Found a good deal on a Cobra Motor Builders lathe. It is a bit different than the cheaper cobras. Better carriage and has billows to keep shaving out of the workings. Plus it has a power base for it's own battery source. Came with 3(2 new in pac) diamond bits. Not bad for A $100. Funny thing after I bought it was I could not really find any loose cell NIMH batteries. PMed Eddie and asked him and he said he had a "few". Got a package in the mail today.......Let's say I have more than enough now |
03-10-2012, 06:22 PM | #1705 |
| Re: Cutting a motor commutator & motor tweaks |
03-10-2012, 06:25 PM | #1706 | |
Team Cobra Com Lathes Towards the bottom. | |
03-10-2012, 06:28 PM | #1707 |
Now that's fancy!
03-10-2012, 06:32 PM | #1708 |
Also was sort of a throw back day as well. Been several years since I've actually built a battery pack. Flashbacks!!! |
03-10-2012, 07:10 PM | #1709 |
Whatever. |
03-10-2012, 07:45 PM | #1710 |
Quarry Creeper Join Date: Apr 2010 Location: The basement of the science building.
I'm glad there was nothing on my calender today. I spent half of it reading this thread. Nice job, fellas! |
03-10-2012, 07:53 PM | #1711 |
Those little chip guards are pretty cool! You have been on a mission for tools tedrockz!
03-10-2012, 08:01 PM | #1712 |
Sorta! On a mission to find a new Orion motor checker. Done the most worst absolute dumbest thing you can do with one to mine. Hooked both leads to the same side of the motor. Was bout half assed tired and was not paying attention. It let out the magic smoke and I could not gather it back up. Probably settle for the Muchmore unit instead. Pulled the Orion apart and it has Muchmore printed on the board. |
03-10-2012, 08:35 PM | #1713 |
Did you fry the traces, or just the FETs? I would wager it was just the high side FET that let out the magic.
03-10-2012, 08:44 PM | #1714 |
Why don't they put fuses in there for that? You would think it would be a no-brainer...
03-10-2012, 08:59 PM | #1715 |
A fuse wouldn't catch it quick enough before the FET goes, unless the FET is way over rated. In that case the next weakest link goes, which is normally a pcb trace. The only real solution is pulse by pulse current monitoring with a high enough impedence in the system to help clamp the current before things melt down. None of the old brushed motor tools had current limiting, they are all simple pulse width modulators with no feedback circuits.
03-10-2012, 09:15 PM | #1716 | ||
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
I should put a wing on my truck for more downforce. Quote:
Most of my average 8 gate courses take about 150-175mah out of my packs. Only thing I've noticed though, is that my 40C packs don't have quite enough grunt at times. It seems that the motors draw more current under Heavy low RPM loads possibly causing my batteries to amp out. Any ideas what kind of amps these motors are capable of drawing?? Maybe I need a higher C pack to get through binds. | ||
03-11-2012, 06:48 AM | #1717 |
You do get really good runtimes on them compared to the other feedback I've gotten! It is in a 2.2 though, and I was thinking supers on the battery. You're probably one of those smooth drivers that doesn't grunt through everything ;) A 35t can burst over 100 amps pretty fast in a stalled condition, measured in the vehicle. Heck, I've even bench measured over 500 amps on a stalled 55t motor on 7 volts. So it just really depends on how deep you bury the throttle, the battery resistance, and how slow the motor is spinning. Bottom line is that you will need more battery power than a regular 35t or similar CrawlMaster because of the efficiency loss. Even though I'm not so fond of the skewed arms, I still brought another batch in with the last Sagami shipment. It's not like my opinions are THE answer. I just like pushing towards efficiency of design whenever possible. |
03-11-2012, 08:53 AM | #1718 | |
I guess with battery that only puts out 34 amps, its definitely amping out the packs. Damn, what to do now..... Really don't want to go back to 1000mah packs.... Maybe the Thunderpower 65C packs would be better. | |
03-11-2012, 09:20 AM | #1719 |
Nobody Join Date: Sep 2008 Location: Maine
03-11-2012, 12:43 PM | #1720 |
That was with a matched sub-c pack. A modern 5000mah 2 cell lipo is even lower resistance. You bet the motor was screaming for mercy! So was the amp meter Nothing got damaged but there was a bit of smoke. You could also try shortening your wires or stepping up wire diameters to reduce the voltage drop. Every little bit helps, even if the battery is taking a beating. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/223989-cutting-motor-commutator-motor-tweaks.html | ||||
Hiilimoottorin kunnostaminen | This thread | Refback | 10-04-2011 03:19 PM |
