05-03-2010, 10:59 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Moses Lake
| Rear steering help
I have recently added a bec because my fxr was overheating with a 3s lipo. The problem is it takes up the 4th channel I want to use for rear steering. Is there any way around this other than not running a 3s? Thanks for help!
05-04-2010, 12:21 AM | #2 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
What RX are you using? There should be a bat port on it for the bec to plug into. That should leave the 4th channel open. This should give you some info also, Definitive wiring diagrams for BECs Rx Servos Motors etc. Last edited by 70duncan; 05-04-2010 at 12:27 AM. |
05-04-2010, 01:12 AM | #3 |
Rock Crawler Join Date: Jan 2009 Location: Christchurch, New Zealand
Hey Jay, You can also power the servos direct from the BEC, and power the RX from the FX-R as normal. That would free up your Ch4 port. Cheers, Mike. |
05-04-2010, 08:41 AM | #4 |
I am using a 4pk.
05-04-2010, 08:54 AM | #5 |
After looking futrther the battery port is channel 4. I read throught alot of the thread from above and good info. I am an still not getting it and I have one more twist, I want to run my dig as well as rear steer. So I have 3 servos. What do i do.
05-04-2010, 10:06 AM | #6 |
Rock Crawler Join Date: Jan 2008 Location: Knoxville
if you don't feel like messing with wiring, just get a servo y harness and plug the bec into one side and a servo into the other.
05-04-2010, 05:18 PM | #7 |
Hey Jay, Here's a diagram from that thread above that shows how to wire up the BEC either as I have said, direct to the servos, or as Lushtrucker says using a Y-harness. Definitive wiring diagrams for BECs Rx Servos Motors etc. Cheers, Mike. |
