09-15-2010, 01:31 AM | #1 |
Newbie Join Date: Jul 2010 Location: Italy
| Sanwa M11X dual esc configuration...
Hi i need to set my Sanwa M11X for a MOA Crawlers. Some days agò i have read the Harley's guide for Futaba 4PK and it's ok for this but now i need to set my sanwa M11x for MOA with dig function. Thank you for all... Livio |
09-15-2010, 07:11 AM | #2 |
Never even heard of it, I don't think it is common in the states. Do you have instructions? Does it have mixing?
09-15-2010, 07:49 AM | #3 | |
I need mixing two esc of my Berg Tracer 2.2 with dig function. I know this configuration for Futaba 4PK but i need to config it on my Sanwa M11X. Some time's agò i have see this configuration by HARLEY0706 4PK Setups, Tips, Tricks and Help Now i need to copy this config on my Sanwa M11X Today i have see this: Airtronics M11 settings for "push-button" dig control This is a config for dig with servo, but i need to config a dig with 2 esc no servo. Thank you Livio | |
09-15-2010, 07:51 AM | #4 |
Sounds like you will have to crack open that instruction book and start playing around with it.
09-15-2010, 08:04 AM | #5 |
| No, i need to config M11X for dual esc settings with dig function |
09-15-2010, 08:32 AM | #6 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
What John said was to read the instruction manual and see if it tells you how to set it up.
09-15-2010, 08:39 AM | #7 | |
The dual esc settings with 4PK Futaba not are write on manual instruction of Futaba... Harley0706 has write settings for this but no for Sanwa... | |
09-15-2010, 09:59 AM | #8 |
Does it tell you how to mix with master and slave channels? ch 2, front ESC Master ch 3, rear ESC slave channel Mix at 100%, then have a button or dial to turn the mix on and off. Since I have never seen the radio, I can't tell you HOW to do it. Only how it could be done in theory. |
09-15-2010, 11:55 AM | #9 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
Don't know how much difference there is between the M11X and an old M11, but I used this thread: Airtronics M11 Settings for Dual Motor Dual Servo Crawlers and was able to get my M11 to run two esc's. And I can vary the speed of the rear esc with the knob, and have front and rear dig. If you need I can look when I get home and post up how I set it up. |
09-15-2010, 12:36 PM | #10 | |
Rock Crawler Join Date: Dec 2009 Location: Ontario Canada
Nice! I have the M11 Radio as well and there's soooo many features on it..It can almost do anything when set up right | |
09-16-2010, 08:53 AM | #11 | |
