Thread: Setting Up Dual Fxrs & Qs
Old 03-15-2011, 04:25 PM   #1
Question Setting Up Dual Fxrs & Qs
Just curious how I set my fxrs up settings wise? Also my xrs reverse jolts maybe cause the escs arent setup? And lastly sometimes only the front or rears spin under load until I squeeze the throttle more than 1/4 in.
Thanks
EEM-CrawlinMachine is offline   Reply With Quote
Old 03-15-2011, 06:20 PM   #2
Thanks
Make sure you set your throttle EPA's to 100 and calibrate each esc separately. i.e. turn one off, then calibrate the other, and then do the opposite on the other one.
As for the jolting, it's possible to get the wires mixed up soldering your motors, and you may need to switch some things around.
As for setup of the esc's themselves, are you using the buttons or a Hotwire to program them?
PaloAltoK5 is offline   Reply With Quote
Old 03-15-2011, 06:44 PM   #3
I wired it all right, not sure what I can change? As far as settings I'm using buttons
Old 03-15-2011, 08:54 PM   #4
We need more information...
What exactly is you problem?
What radio are you using?
What motors do you have?
Any other specs would be helpful.
SMR 510RR is offline   Reply With Quote
Old 03-15-2011, 09:53 PM   #5
Under load sometimes only 2 wheels spin until I go over 1/4 throttle
My reverse is strong but pulses
Integy 55t motors
RC4WD xr4 radio with a wantAsummit mix unit
Old 03-15-2011, 11:16 PM   #6
Using the buttons:
Drag Brake: press the mode button once so the 1st LED is lit up, then press the INCR button until the last LED is lit up. This will put you at 100% Drag brake.
Reverse Strength: Press the MODE button twice so the 2nd LED is lit up, then press the INCR button until the last LED is lit up. This will put you at 100% Reverse Strength.
Current Limit: Leave at default
Push Control: Leave at default
Reverse Type: Press the MODE button five times so the 5th LED is lit up, then press the INCR button until the 1st AND 2nd LED is lit up. This will put you in immediate forward/reverse mode.
Low Voltage Cutoff: Press the MODE button six times so the 6th LED is lit up, then press the INCR button until the 2nd LED is lit up for 2s Li-Po or until the 3rd LED is lit for 3s Li-Po.
That's it, you are set up. Do this for each unit.
As for the not moving until 1/4 throttle, still sounds like a calibration issue to me. What pinions are you running on your 55t motors? Are both motors timed the same?
Old 03-16-2011, 01:17 AM   #7
Yea, recalibrate both esc's. Make sure the mix unit is at neutral when you calibrate.
Also, check the timing on your motors, if they were timed anything other than 0 deg. from the factory then you are running one of them in reverse. If they are both 0 then you should be ok or if both are advanced the same amount you will be good. Take the rotation direction into account when checking them, obviously one should go the opposite direction than the other.
Can you describe the situation where you are having the problem? How bad of a bind are we talking about, does one axle seem stronger in general, are you climbing when it happens?
I have no idea why reverse would be "pulsing"...That doesnt seem ESC related unless its just a calibration issue. Are you running a BEC? Is it wired through the receiver? Does the light on it cut out? Seems more like a radio glitch to me.
Old 03-16-2011, 08:57 AM   #8
It only does 2 wheels on light loads climbing, my reverse worked fine with only 1 fxr on my scaler
How do you time motors? Both motors using 14t pinions
Thanks
Old 03-16-2011, 11:56 AM   #9
Try this, just check it based on the markings on the can and endbell.
Caring for your new Brushed motor
You can search for "Timing" in electronics for more info if you need it.
Old 03-16-2011, 04:32 PM   #10
AS stated recal. the escs, i just unplug one at a time to do this... Not sure about the mixer? yer using...
dickwart is offline   Reply With Quote
Old 03-17-2011, 09:19 AM   #11
Thanks guys. Any ideas on the pulsing reverse?
Old 03-18-2011, 10:43 AM   #12
Anyone?
Old 03-18-2011, 11:03 AM   #13
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
It is best to program both ESC's at the same time. I have walked probably HUNDREDS of people through programming their stuff as well as countless of my own. Programming both at the same time is always the best method for dual FXR's.
Harley is offline   Reply With Quote
Old 03-18-2011, 11:56 AM   #14
I agree although it takes some flexibility or someone else to help you at least if you take the on/off switches off.
Old 03-18-2011, 11:59 AM   #15
20K Club
Harley's Avatar
I just put a rubberband around the throttle
Old 03-18-2011, 12:04 PM   #16
eh...ok, I am confused then, how do they find neutral and reverse if you rubberband the throttle while calibrating?
Old 03-18-2011, 12:15 PM   #17
20K Club
Harley's Avatar
You only need to do it at the begining when you plug that battery in so you don't need another set of hands (on the castle stuff only now that I think about it). FXR's I can push both buttons myself without a problem.
Old 03-18-2011, 12:18 PM   #18
Ah, ok....see, now don't be confusing peeps, silly harley!
Old 03-18-2011, 12:29 PM   #19
One more thing, when calibrating, remember you have to have them wired correctly, or the radio F/R set correct for each channel so it calibrates them both forward when you pull the trigger, and both reverse when you push it. I don't know how many times I have checked peoples setups and after neutral is detected I pulled the trigger and one esc calibrates forward and the other thought I was it reverse and wouldn't calibrate....annoying, but easily solved. Just keep this in mind.
Old 03-18-2011, 06:13 PM   #20
You are talented if you can push both buttons and plug in the battery at the same time. Took me like 20 minutes to get it haha.
