12-19-2011, 01:29 AM | #1 |
Newbie Join Date: Nov 2011 Location: Huntington Beach
| Help with Radio setup
I am building an Axial XR10 with 2 Tekin FXR's and 45t motors. I will be using am Airtronics RDS-8000 radio. I am looking for a starting place for the settings, I would like to run throttle and steering on the right stick and use the 3 position switch on the right for front rear dig. Any help would be greatly appreciated!! Paul Last edited by PaulSR; 12-19-2011 at 01:50 AM. |
12-25-2011, 11:11 PM | #2 |
| Re: Help with Radio setup
ok, i have the radio partially set up. now the issue is that one motor starts before the other, any ideas on how to resolve this???
12-26-2011, 07:46 AM | #3 |
I'm assuming the rear motor is the "slow to start" one? That's "clod stall". I will assume both ESC's are calibrated to the RX? All settings are the same in each ESC (firmware, throttle curves, etc?) If your issue is clod stall, some "fixes" are: Different pinion front vs. rear A little proportional to add more power to the rear motor sooner Check that pinion mesh is good front & rear Make sure both motors are in good shape (decent comm., good brushes) |
Help with Radio setup - Similar Threads | ||||
Radio Setup | JonU | Electronics | 11 | 05-27-2011 01:05 AM |
Radio and esc setup | Jedda | Axial XR10 | 2 | 01-15-2011 12:35 PM |
Radio setup help | Axialfan19 | Electronics | 0 | 08-31-2010 01:16 PM |
Radio Setup Help | bondo303 | Electronics | 5 | 03-17-2009 09:54 AM |
radio setup question | crawldad91 | Electronics | 2 | 09-05-2008 06:53 AM |
