12-28-2011, 07:13 PM | #1 |
RCC Addict Join Date: Aug 2009 Location: Earth?
| Hitec HSR-5990TG Overload Protection Bypass
I Bought this servo about two years ago to use on my comp rig. Ran it maybe 3 or 4 comps and it started not responding when in a heavy bind. I sent it to Hitec thinking something was wrong with it. Turns out its working fine. It has a built in overload protection. So its been sitting useless in my desk ever since. I even pluged it in a servo programmer to try and turn the overload off, and could not turn it off. Is there some way I can solder something on the board to bypass the overload? Link to specs HSR-5990TG Servo Control System: +Pulse Width Control 1500usec Neutral Required Pulse: 3.3-7.4 Volt Peak to Peak Square Wave Operating Voltage Range: 4.8-7.4 Volts Operating Temperature Range: -20 to +60 Degree C (-68F to +140F) Operating Speed (6.0V): 0.15 sec/60° at no load Operating Speed (7.4V): 0.12sec/60° at no load Stall Torque (6.0V): 333.29 oz-in. (24kg.cm) Stall Torque (7.4V): 416.61 oz-in. (30kg.cm) Standing Torque (6.0V): 433.27 oz-in. (31.2kg.cm) 5 degree deflection Standing Torque (7.4V): 541.59 oz-in. (39kg.cm) 5 degree deflection Operating Angle: 60 Deg. one side pulse traveling 450usec 360 Modifiable: Yes Direction: Clockwise/Pulse Traveling 1500 to 1950usec Idle Current Drain (6.0V): 3mA at stop Idle Current Drain (7.4V): 3mA at stop Current Drain (6.0V): 300mA/idle and 4.2 amps at lock/stall Current Drain (7.4V): 380mA/idle and 5.2 amps at lock/stall Dead Band Width: 2usec Motor Type: Coreless Metal Brush Potentiometer Drive: 6 SliderIndirect Drive Bearing Type: Dual Ball Bearing MR106 Gear Type: 4 Titanium Gears Connector Wire Length: 11.81" (300mm) Dimensions: 1.57" x 0.78"x 1.45" (40 x 20 x 37mm) Weight: 2.18oz (62g) Pic of each side of the board. |
12-28-2011, 07:47 PM | #2 |
| Re: Hitec HSR-5990TG Overload Protection Bypass
How it is powered?? Is it through the RX or direct from an external BEC?? I ALWAYS use a direct connection from the external BEC to the servo. |
12-28-2011, 07:54 PM | #3 |
Rock Crawler Join Date: Jan 2009 Location: Christchurch, New Zealand
Do you have the Hitec programmer with the computer software? Can you post up screen shots of the settings and options? Are you able to change the overload setting to not drop the power so much? It's been a while since I've run the software on servos, but from memory there was the ability to set the power reduction % for the overload. Cheers, Mike. |
12-28-2011, 07:56 PM | #4 |
It was powered straight from the BEC. Tried it at 6.0v and 7.4v. Both with the same result.
12-28-2011, 08:07 PM | #5 | |
| Re: Hitec HSR-5990TG Overload Protection Bypass Quote:
Thanks for the idea. I will try it out. | |
12-28-2011, 08:12 PM | #6 |
The other thing to consider is the size of your battery - mAh, and C rating. This will determine the maximum amp draw....and may also be a cause of the problem.... Easy enough to test by throwing in a bigger battery... Cheers, Mike. |
12-28-2011, 08:21 PM | #7 |
1300mah 30C, and 1100mah 45C.
12-28-2011, 08:54 PM | #8 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
I think it is percentage of bypass is too high. I run 10% on my comp rigs
12-29-2011, 08:18 AM | #9 |
Im gonna borrow the programmer again and see if I can change the % value.
12-29-2011, 08:34 AM | #10 |
You can use the programmer any time Karl let me know. |
12-30-2011, 07:13 PM | #11 |
Well programming was a waist. This is what I get when I tried. The servo says "digital" right on the case. What a bummer....
12-31-2011, 10:46 AM | #12 |
I was able to test the servo with the programmer, it works fine. Works when pluged into a receiver. But, without the programmer recognizing it as a digital servo I cant do anything with it. It goes back to the first post. Is there something on the board I can solder to bypass the overload? |
12-31-2011, 02:00 PM | #13 |
Do you know that you have to hook a receiver pack or 4 AA's to power the servo? I know it's weird and it should power through USB, but it doesnt. That message is exactly what you get when no battery hooked up to programmer.
12-31-2011, 04:37 PM | #14 | |
Sure do. I had a receiver pack hooked up. Even checked the voltage on the receiver pack. It was 6.80v. Thanks for asking though. | |
Hitec HSR-5990TG Overload Protection Bypass - Similar Threads | ||||
Servo overload protection? | Fattymojo | Newbie General | 4 | 07-13-2010 09:29 AM |
Hitec 5990TG Servo Trouble. | JSSuper | Electronics | 11 | 03-18-2009 11:15 AM |
Hitec HSR-5990TG | Georgerm | Electronics | 4 | 07-18-2008 06:34 PM |
Hitec HSR-5990TG or HS-5955 servo, Which is better? | mail2n | Electronics | 13 | 03-18-2008 10:01 PM |
Hsr-5990tg | SVEN | Electronics | 9 | 06-09-2007 11:29 PM |
