01-01-2012, 05:25 PM | #1 |
Newbie Join Date: Dec 2010 Location: prince george
| Savox servo on xr10
So I was thinking about getting a savox. I don't know the specs on them and hoping you-all can help me. I am running a hobico cs170 now and its ok at 6v but a lil more would be nice. So how are the savox servos and any certain one I would like the best. Thanks
01-01-2012, 07:06 PM | #2 |
| Re: Savox servo on xr10
You are likely looking for a torque output of ~300inoz or more. Compare your current servo specs and then check the Savox specs to see where you end up. If you don't already have one, you are getting into the range of needing an external BEC. |
01-01-2012, 08:27 PM | #3 |
Yep got the ccbec. But I swear the savox page don't have tq specs iirc
01-01-2012, 08:30 PM | #4 |
Rock Crawler Join Date: Oct 2011 Location: smithville
Go with a hitec 7950 or 7980. These are both great so I would consider these.
01-01-2012, 08:34 PM | #5 |
The 7980. Any mods to fit it. And what spline horn is it. What about specs. Thanks
01-01-2012, 08:38 PM | #6 |
Specs are 6v is 500oz and 7.4v is 611oz! Pretty sick I got one for my xr and still have to put it, so I am not exactly sure how to fit it just yet. It does fit with a little squeezing as others have done it. There are a couple threads about fitting one in.
01-01-2012, 09:02 PM | #7 |
Ya that's very impressive numbers. Worth any Modding. Thanks for info.
01-01-2012, 09:07 PM | #8 |
Pebble Pounder Join Date: Mar 2011 Location: Calgary, Alberta
I just slit the hole on the mount and installed it.
01-01-2012, 10:29 PM | #9 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
Have a savox 1268... specs Dimensions(mm): 40.3x20.2x37.2 Weight(g): 62.0 Speed(@4.8V sec/60): .15 Torque(@4.8V oz-in): 160.0 Speed(@6.0V sec/60): .13 Torque(@6.0V oz-in): 208.3 Speed(@7.4V sec/60): .11 Torque(@7.4V oz-in): 347.2 Gear: Unique Steel Bearing: 2BB Case: Aluminum 25 Tooth Spline I like it...and just around 80 bucks in most places |
01-02-2012, 06:43 AM | #10 | |
| Re: Savox servo on xr10 Quote:
Not sure on the 7980, it's a bit big, a 7950 is decent & is a "standard sized" servo. 7980... TowerHobbies.com | 37980S Hitec HS-7980TH Digital Mega Torque HV TG Coreless 7950... TowerHobbies.com | 37950S Hitec HS-7950TH HV Digital Ultra Torque Coreless TG | |
Savox servo on xr10 - Similar Threads | ||||
Savox SA-1283SG Servo | kyrzrone | Electronics | 27 | 05-18-2012 02:29 AM |
savox servo | weese78 | RC4WD Bully | 5 | 01-22-2011 12:33 PM |
Savox servo?? | mnypit71 | Electronics | 4 | 01-10-2011 10:23 PM |
