01-02-2012, 11:31 AM | #1 |
Rock Stacker Join Date: Mar 2011 Location: by the ocean
| My dingo will not go slow.
I recently built the dingo kit. I am running an axial ae-1 with reverse (which isn't working) with an axial 27t motor on a 2s lipo. All was fine and dandy (minus the reverse) until I couldn't make the motor go slow. The esc shows I'm giving it gas but it'll only move at high speed. I feel like its the motor but I know the reverse not working might be a sign. I've messed with all the trims on my radio (gt3b) and I'm completely stumped. Any advice?
01-02-2012, 11:44 AM | #2 |
| Re: My dingo will not go slow.
Hi, sorry for your issues. So, you're running a GT3B.....did you calibrate your AE-1 ESC to the RX? The 27T may be a bit hot, you may be able to dial some of that out. Is your GT3B stock or LosiKid modded/hacked? |
01-02-2012, 12:19 PM | #3 |
I couldn't figure out how t.o get it into calibration mode because the manual that came with it just says no programming necessary.
01-02-2012, 12:21 PM | #4 |
Both manuals are on the Internet, find them & use them. What you described appears to be that the ESC is not calibrated to the RX.
01-02-2012, 12:23 PM | #5 |
I couldn't figure out how to get it into calibration mode because the manual that came with it just says no programming necessary. I've tried looking for a reset button and I've tried holding down the trigger waiting a bit the going full reverse and then neutral and it seems then it arms but same problems.
01-02-2012, 12:58 PM | #6 |
Some ESC's (like Castle Creations) have you hold "full forward", power on the ESC, wait for a chime, hit full reverse, wait for a chime, go to neutral, you're done. Get both of your manuals so you are better informed. From your lack of reply, I will assume you have a stock GT3B???? |
01-02-2012, 05:26 PM | #7 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
just curious Charlie...what diff does it make if its a hacked GT3B or not. I to would calibrate esc to receiver, then report back...just like Charlie says |
01-02-2012, 05:39 PM | #8 |
Yeah from the OP that definitely sounds like a TX not properly calibrated to the ESC. A 27t on 2s shouldn't be acting that way...I don't use a GT3B but several people on here do. Also how is it that your reverse on the AE-1 doesn't work? Didn't know you could lock out reverse on the AE-1...
01-02-2012, 07:31 PM | #9 | |
| Re: My dingo will not go slow. Quote:
I figured it would be worth knowing everything possible just in case someone knew a "quirk" between a stock vs. hacked GT3B. Sound OK to you? | |
01-02-2012, 08:09 PM | #10 |
Sorry about the slow reply. We drove our to the ranch. Yup its a stock gt3b. And it would go slow at first just not anymore. I'll keep messing with the tx and see what happens.
01-03-2012, 12:48 PM | #11 |
Lots of tweaking and no dice. Is it possible there is a problem with the motor?
01-03-2012, 01:19 PM | #12 | |
Your issue is likely either radio related or ESC. Basic AE-1 manual.... http://docs.axialracing.com/instruct...01-ae1-esc.pdf ****************** From their FAQ page: I decided to sit down with our customer service reps recently to see what kind of questions they get asked the most on a week to week basis. Some of the questions they get asked I expected, and some I didn’t. So, I decided to highlight the most popular questions here on the blog, with answers. Hopefully, this will help newcomers find solutions for their issues even faster. Electronic FAQs: Q: Can I program or bind my AE-1 ESC (Speed control)? A: No programming or binding is necessary on the AE-1 ESC. Q: How many cells or volts can the AE-1 ESC handle? A: 6 cell (7.2 volt) , 7cell (8.4 volts) or a 2s Lipo (7.4 volts) Please note AE-1 ESC does not have a Lipo cutoff. AE-1 ESC requires a low voltage cutoff if using lipo batteries. ***************** So yes, it appears there is no programming available on the AE-1. So it's either an ESC issue (one that you can't fix) or a radio set-up issue. | |
01-03-2012, 01:42 PM | #13 |
Plug a servo into your throttle channel and see if the trigger controls the servo in both directions fully...That should help to troubleshoot what is causing the problem. My guess would be a bad ESC as it seems like it is acting strange. Make sure your endpoints on the throttle channel are maxed out. If the radio will move a servo reliably then it has to be the ESC. I doubt it is a motor problem. There is no motor problem that I can think of that would cause the kind of problems that you are having. Good luck! |
01-03-2012, 02:54 PM | #14 |
| Re: My dingo will not go slow. |
01-03-2012, 04:10 PM | #15 | |
My dingo will not go slow. - Similar Threads | ||||
I'm old and slow............ | ridepate | General Scale Talk | 6 | 12-13-2011 10:33 PM |
Slow.....MO | Mayhem Eng. | Chit Chat | 6 | 10-24-2011 03:01 PM |
How to slow it down | wamf | Tamiya XC/CC01 | 42 | 07-07-2009 07:38 PM |
how slow??? | rockhound | Tamiya TLT Crawlers | 5 | 12-09-2004 10:29 AM |
