01-09-2012, 12:25 PM | #1 |
Newbie Join Date: Nov 2011 Location: Austin
| esc+motor connections
Just finally have everything to hook up electronics. Im using a castle vapor esc off my savage xs until I can get ahold of a holmes brxl esc. Besides battery wires there are three spots to connect wires(a,b,c). I've tried searching with no luck. Could someone please try and just explain the right way to connect this to my new brood motor. I do have the castle link card so I can adjust esc if need be. Thanks
01-09-2012, 02:34 PM | #2 |
| Re: esc+motor connections
likely the brood motor will be hooked to a (+) and c (-) but first the esc must be set to brushed mode with the castle link being if it has a brushed mode setting.
01-09-2012, 02:45 PM | #3 |
| Re: esc+motor connections |
01-09-2012, 03:18 PM | #4 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
If you are running a Brush motor that is correct. As Benoj said you use A (+ve) and C (-ve). Have your changed the running mode over to Brushed with castle link? If not, it wont work at all. |
01-09-2012, 05:38 PM | #5 |
| Re: esc+motor connections K, just got my link today so I should have it running tonight. Just wanted to get all the info first. Thanks guys
esc+motor connections - Similar Threads | ||||
lights connections | chiatw73 | G-Made Crawlers | 2 | 01-24-2011 10:26 AM |
Sidewinder esc and 5700 motor or Traxxas vxl 3s esc with brushless motor? | THE CRAWLER KING | Newbie General | 6 | 08-22-2010 07:10 AM |
Wiring connections? | mhuffman_81 | Electronics | 17 | 07-30-2009 02:32 AM |
axial ESC connections whoops :S | LS1Armyboy | Newbie General | 4 | 04-04-2009 03:03 PM |
motor wire connections | ax10scorpion89 | Electronics | 2 | 12-29-2008 01:08 PM |
